It is currently Fri Mar 06, 2026 5:28 am
Post new topic Reply to topic  [ 509 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 34  Next
PostPosted: Thu Jan 11, 2018 12:26 pm
PostPosted: Sun Jan 14, 2018 10:54 am
PostPosted: Sun Jan 14, 2018 11:16 am
Hi G, I think the blockage won't affect anything but the clutch pack I'm a little concerned with as the last drive plate protrudes a little from the clutch drum and is tight against the circlip, I bought the kit from Justin who is Protwin in Perth, I believe he was Brook Henry's understudy, I might chuck it on the trailer and give him a visit to clarify some,
PostPosted: Sun Jan 14, 2018 2:09 pm
Now I'm really confused as I have just removed the new clutch set and measured the stack height compared to the set I am replacing and the new set is appx 2.5 mm lower than the old so I can't see why barnett set sits proud of clutch drum yet the old set not reaching the external edge of drum as in pic,
PostPosted: Sun Jan 14, 2018 3:50 pm
That really is odd and would only make some sense if the last Barnett steel disc was a warped one which according to the installation manual it isn't.
You removed the red springs again? Just asking. That has nothing to do with the problem.
PostPosted: Sun Jan 14, 2018 4:15 pm
My suspicion might be correct since I found this file online. It's the same Barnett clutch number but with a different setup. This one has a curved disc. The number of discs is not the same as shown in the instructions you posted. Which one corresponds to what you have?
PostPosted: Mon Jan 15, 2018 6:08 am
Yes mate the instructions I posted are exactly what I have, I will try fitting the old set and see what happens there, thanks and I'll let you know the results
PostPosted: Mon Jan 15, 2018 10:32 am
Before trying old set I will post a pic of the clutch nut and amount of thread showing on the shaft, maybe I have got something wrong and the clutch drum isn't sitting where it should, and I'll look back for that on my disassembly photos, I may have to go back a bit , take clutch nut back off, I broke my homemade clutch tool torquing her up and the lock washer is toast so mighty be such a bad idea anyway, cheers
PostPosted: Mon Jan 15, 2018 10:36 am
I had set torquewrench to 180 or so but didnt quite get there when my shit welding gave up, maybe 150 I got
PostPosted: Mon Jan 15, 2018 10:40 am
PostPosted: Mon Jan 15, 2018 10:43 am
I may need to find a reasonably priced tool on ebay or maybe I should have another crack at making one from the old set as the original was only one thin driveplate
PostPosted: Mon Jan 15, 2018 11:20 am
I had a look at my dismantle pics and the thread length visible same as now so I'm guessing my parts sequence must be right, but now with the old clutch set , springs and control plate in place the outer driveplate sits exactly where the barnett unit was sitting, ie, proud of the clutch drum as in this pic
PostPosted: Mon Jan 15, 2018 11:24 am
As you can see its in one of the last pics before i stripped it, the plate was not proud, maybe thats just how they are until its actually been charged up and used?
PostPosted: Mon Jan 15, 2018 11:31 am
this tool works fine
https://www.ebay.com/itm/Ducati-Clutch- ... cw&vxp=mtr
They sell similar ones on ebay Australia, too but there they cost a little bit more.
PostPosted: Mon Jan 15, 2018 6:17 pm
...........'cept it didn't break :D
