ducatipaso.org • View topic - Ducati 907ie Rectifier
It is currently Mon Mar 02, 2026 8:34 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
 Post subject: Ducati 907ie Rectifier
PostPosted: Sun Jan 28, 2018 10:45 pm
I have found a UK supplier of this which I believe is supplied by Electrosport in the states are they suitable replacements?
http://www.electrosport.com/media/catal ... r510_1.jpg
https://images-na.ssl-images-amazon.com ... L1000_.jpg
 Post subject: Re: Ducati 907ie Rectifier
PostPosted: Sat Feb 03, 2018 12:46 pm
ANY ONE KNOW - ARE THEY ANY GOOD/
PostPosted: Sat Feb 03, 2018 1:06 pm
Looks, that such is not Electrex. I dont know realibility of those, but Electrex is very good one. Stiv, if You want Electrex, i think, that they have importer from USA to UK .... As last time, when i ordered them from USA(3 units), items came to me from UK, not direct from USA! ....and then i had not to pay any taxes, VAT's etc...
Antti
PostPosted: Sat Feb 03, 2018 1:09 pm
Still one note: Take all such connectors away and WELD wires very well and insulate them with 2 layers of heat shrink! Most of those regulator/generator problems are caused by poor/resistive CONNECTORS ! I know, i am elecrician... :thumbup:
PostPosted: Sat Feb 03, 2018 5:22 pm
:thumbup: Antti
PostPosted: Tue Feb 06, 2018 10:49 am
Stiv, why are you looking for a regulator in the first place? You mentioned you already had more than one. Imho it makes no sense spending the money if you're not certain that's the main issue.
PostPosted: Tue Feb 06, 2018 2:50 pm
If regulator is failed, it can broke also alternator in left side of engine and SAME VIA VERSA. Allways with such problems have to measure insulations of generator (with suitable insulation meter/tester, what gives 250 test voltage!)and also all wires with Ohm meter. Regulator CANT be measured 100% surely, no matter in some Haynes Ducati manuals are noted some ohms between regulatos wires. Also regulator plate(case) ground must be 100% to bike frame! Same with wires from regulator to battery! Most these "cases" are coming from poor connectors between regulator and generator in left side little under steering head bearing. Also ST-series bikes suffer from these POOR/DIRTY connectors in same wires.
PostPosted: Wed Feb 07, 2018 9:34 am
PostPosted: Wed Feb 07, 2018 10:29 pm
My problem is that I want to test a brand new perfect Regulator/rectifier for a base level test as everything else seems to pan out okay.
All three current units that I have are just frustrating the issue as they all give a varied and different perspective.
Neither are for certain giving me any charge rate.
I have cut away as much of the shrouding that I can on the loom and apart from some oily damp residue no sign of scorch or burn marks, none of the plug sockets are corroded or damaged, Fuses are perfect and new.
All the earths are clean.
The engine on/off switch is in perfect working order and the spare when fitted gave the same results.
I am going to try some new Relays and I have a used but good Power Module waiting to be collected at the Post Office (all the way from Hawaii !!)
It is being a pig of a job to suss out what is the gremlin lurkin underneath.
I am also considering trying to find a local company that might be able to confirm if the ECU is at fault somewhere.
Please appreciate guys I am on a limited budget spend with my bikes and don't have access to unlimited funds for top dollar bespoke gear on this bike or any of my bikes for that fact. :thumbup:
PostPosted: Wed Feb 07, 2018 10:43 pm
PostPosted: Wed Feb 07, 2018 10:52 pm
PostPosted: Sun Feb 11, 2018 11:14 am
Stiv, I have also one spare power module in my shelves, but never needeed it yet. It was from some car what use same module and exact same numbers on it. I have also some spare 907ie ECU's if You need such. But never use any multimeter to test MOSFET Regulator! MOSFET is such component (inside unit), that need to "ground yourself" as it needs only small voltage peak and such is dead then. There can be MOSFET regulators, but i havent seen such in Ducati spare part markets. Those originals are "crap" and Electrex is best.
Antti
PostPosted: Sun Feb 11, 2018 11:16 am
Btw, You are "lucky" if generator is ok, as if it fails, then it cost doubble (to rectifier) and have to open left side of engine... :thumbup:
Antti
PostPosted: Mon Feb 12, 2018 9:48 am
PostPosted: Mon Feb 12, 2018 10:22 am
Thank's Derek! I know, that many Duck's use Shindengen jap regulators, but i didnt know that they use MOSFET's inside them. .....have to use more "google search" :mrgreen: :thumbup:
