It is currently Fri Jun 19, 2026 10:52 am
 Post subject: Mikuni conversion?
PostPosted: Sat Dec 30, 2017 5:52 pm
I have gotten my 750 sport out to finish my upgrades, anyone have any specifics on the oe mikuni conversion ( jetting, fuel pressure restriction...)
90' 750 Sport
97 Gsf1200 aka Ziptie
78' 900 GTS (bevel)
98' Gsf1200 bagger
86' GSXR712
 Post subject: Re: Mikuni conversion?
PostPosted: Sat Dec 30, 2017 7:01 pm
Have a look at the P750 FAQs.
PostPosted: Sat Feb 03, 2018 10:14 pm
does the mikuni conversion need the fuel pressure regulator?
90' 750 Sport
78' 900 GTS (bevel)
98' Gsf1200 bagger
86' GSXR712
PostPosted: Tue Feb 06, 2018 10:05 am
If you had a P750 I'd say, absolutely but I don't know if the specs of the 750S in-tank fuel pump are the same as the one used on the Paso. I'd try w/o but do keep the return line to the tank. In case you run into problems try to remove the jet that sits in the Y-piece. This will increase the amount of fuel returning to the tank. If you still have problems you can add a fuel pressure regulator.
PostPosted: Thu Feb 08, 2018 4:09 am
Thanks, will do...
90' 750 Sport
78' 900 GTS (bevel)
98' Gsf1200 bagger
86' GSXR712
PostPosted: Thu Mar 15, 2018 3:09 am
https://www.youtube.com/watch?v=dliSUJACpw8
Awake after 8 years in storage, Mikuni conversion, Verlicci 2 into 1, rear shock rebuilt, forks serviced, new Michelins....
90' 750 Sport
78' 900 GTS (bevel)
98' Gsf1200 bagger
86' GSXR712
PostPosted: Mon Sep 03, 2018 3:44 pm
Not bad from 8th Feb to Mar 15th ;)
