ducatipaso.org • View topic - help needed with front brake light
It is currently Sun Jun 14, 2026 1:54 am
 Post subject: help needed with front brake light
PostPosted: Sat Mar 03, 2018 9:01 pm
getting ready for rego and front brake light wont work
using the rear brake light come on
I have tried to see if its the switch by joining the two wires together with ignition on still not working
the real problem is I am colour blind so tracing wires is not easy
anyone had the problem of the front brake not working the stop light
brakes work fine
thanks
jim
 Post subject: Re: help needed with front brake light
PostPosted: Sun Mar 04, 2018 10:36 am
The usual problem with the front brake switch is that the tiny plastic pushrod has dropped out when the lever has been removed, or the switch itself has packed up but since your stop light isn't working when the wires are joined together you can probably rule out the switch.
Of the 2 wires, one is grey/yellow and the other is just grey. Even if you are colour blind you should be able to see that one has a strip and the other doesn't. The wire with the stripe should have 12V when the ignition is on. Use a test lamp to check that it does. That wire goes straight back to the fuse box and is on the same fuse as the lights and injection (strangely the rear brake light gets it's feed from the other 15A fuse). If there is no 12V on that wire there is either a break somewhere or it has a poor connection at the fuse box (more likely). If the fuse was blown you wouldn't get lights and the engine wouldn't start.
The other wire (plain grey) goes straight to the tail light connector where it is joined by another grey wire from the rear brake light switch. Check it's connection at the tail light and it's continuity from the front brake light switch.
That's about all there is to it.
PostPosted: Sun Mar 04, 2018 10:57 am
A mate come over and there is power so need to trace the other wire must have a brake somewhere
PostPosted: Sun Mar 04, 2018 11:29 am
PostPosted: Sun Mar 04, 2018 2:18 pm
Right enough. I wasn't paying attention again. :roll: I was looking at the diagram for the 907.
Colours are different but principle is the same. Yellow/red to the tall light and blue/black for 12V which looks like it is piggy-backed onto the spade connector of the horn. If there is no 12V that's the first place I'd look.
PostPosted: Sun Mar 04, 2018 3:17 pm
PostPosted: Wed Mar 07, 2018 8:50 pm
I have power and when the power is put to the yellow wire at the last junction box before the tail light the light comes on thinking of just running a new wire all the way from the switch
jim
PostPosted: Thu Mar 08, 2018 3:04 pm
PostPosted: Thu Mar 08, 2018 7:55 pm
thanks for all the help front brake light works now
jim
