ducatipaso.org • View topic - Speedo drive question
It is currently Sat Jun 20, 2026 2:02 pm
 Post subject: Speedo drive question
PostPosted: Mon Mar 05, 2018 4:16 pm
Any idea if the speedometer drive on the 88-90 900SS is the same or is interchangeable with a later or any other models ?
Steve
 Post subject: Re: Speedo drive question
PostPosted: Mon Mar 05, 2018 5:28 pm
yes it is.
As a tip if you want to know something like this check the Stein Dinse website https://www.stein-dinse.biz/index.php?language=en. On the left of it you find the parts catalogues.
If a certain part is available you will find a link to the shop and often there you will find a list of Ducs that use the same part. If the part is not available as in this case you have to check the parts catalogues of different models or you check for the part number and google it.
49810011A fits the 9078IE, 851, 888, 750/900SS up to '97.
Another good source to check interchangeability of parts is http://www.desmoduck.com/index.php but this site only covers newer Ducatis. Some parts that were used on the Paso and Sport were still or are still used on newer Ducatis. The speedometer drive is not one of them.
PostPosted: Tue Mar 06, 2018 7:18 pm
Thanks for the info......
PostPosted: Tue Mar 20, 2018 4:52 pm
Hi guys,
I found this :
https://www.ebay.de/itm/Ducati-900-SS-9 ... 2749.l2649
and ordered one.
The measurements and the stamped on CEV number are the same as on the drive from my '90 supersport 900
Maybe that helps.
PostPosted: Tue Mar 20, 2018 7:07 pm
what's is the CEV number stamped on it?
PostPosted: Tue Mar 20, 2018 8:37 pm
