It is currently Sun Apr 26, 2026 10:11 am
Post new topic Reply to topic  [ 509 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20, 21, 22 ... 34  Next
PostPosted: Wed Apr 25, 2018 1:22 pm
iThanks for explaining that one , I guess they would make it simple if it worked, I will keep it pretty original there, heres a pic of mine , ill start with a good cleanup
PostPosted: Mon May 07, 2018 10:35 pm
Clean and refit the breather tank and with the new hagon shock I have clearance of 2 sheets of a4 paper so pretty tight but should be fine, all the rubber hoses are perished and the 2 short reducing ones may prove hard to replace
PostPosted: Mon May 07, 2018 10:37 pm
PostPosted: Fri May 11, 2018 3:35 pm
Just remembered why I didn't stick with the tomasellis, the adjustle knuckle blocks the brake reservoir sliding up the bar enough to work without a 4 or 5 mm spacer, I was happy with nos original clipons anyway so all good, oh well it beats watching tv , moving forward slowly
PostPosted: Fri May 11, 2018 3:47 pm
A real shame , i think they could have been very nicely adjustable for the old body
PostPosted: Sun May 13, 2018 12:50 am
I I'll see if I can find some suitable spacers to fix this issue as I have put the effort in already and the ergonomic benefits
PostPosted: Sun May 13, 2018 1:38 am
Well I found some nice spacerblocks online and ordered 2 , bit of luck a perfect solution , looking forward to seeing how they go
PostPosted: Sun May 13, 2018 11:32 am
PostPosted: Sun May 13, 2018 11:36 am
If all goes well the bars will sit near to this latest pic but in saying that I must setting adjustable bars up on these are pretty tricky
PostPosted: Mon May 14, 2018 9:44 am
The more I look at this I realise how much goes into seeing if the tomasellis will fit I realise that I really need to set the lower fairing in place as Well , I wish I had of kept at it the first time, but it should be worth the effort
PostPosted: Mon May 14, 2018 9:47 am
I'm only concerned with the throttle side as I've upped the size of the brake reservoir , the other side will work no woz
PostPosted: Mon May 14, 2018 10:59 am
Are there any stops for steering sideways movement?
PostPosted: Mon May 14, 2018 11:57 am
I think the bolts for brake lever will be like stops if I Don't drop down lower to clear triple tree but that will all but defeat the purpose
PostPosted: Sun May 27, 2018 11:22 am
Not a lots changed but I degreaser and cleaned the fairings and setting them up to see how these toma's are going to work, got the spacers so just gotta sort it out and move on
PostPosted: Sun Jun 03, 2018 4:05 am
Verdict is in I'm farkin over it the tomasellis will not work on these bikes !!! I'd like to be proven wrong but I just can't see it , I've even tried them with the stock brake reservoir and no go, can get the res to clear but still hitting fairing to brake lever, lots of work ANF frustration but atleast I know now, I'm sure I could get them to function but there'd be no advantage
