ducatipaso.org • View topic - Algún compañero de habla española o alemán?
It is currently Fri Feb 27, 2026 3:19 am
 Post subject: Algún compañero de habla española o alemán?
PostPosted: Sun May 20, 2018 8:15 am
Tengo alguna pregunta sobre el pistón de embrague y mi ingles es malo saludos
 Post subject: Re: Algún compañero de habla española o alemán?
PostPosted: Sun May 20, 2018 8:22 am
Deutsch ist hier im Forum kein Problem.
Du kannst aber auch auf spanisch schreiben.
In general: we're an international forum so if someone is insecure about his english it's no problem to post in your language whichever it is! We'll figure it out.
PostPosted: Sun May 20, 2018 9:31 am
PostPosted: Sun May 20, 2018 10:16 am
Infos about the clutch slave piston O-ring and alternatives can be found in the FAQs.
You can replace the old O-ring with the V-type seal used on later Ducatis. The part number is: 93040091A. You can get that from Ducati.
PostPosted: Sun May 20, 2018 11:08 am
