It is currently Sat Feb 28, 2026 2:18 pm
[ 4 posts ] |
| Author |
jimg1au
Post subject: 1988 750 SPORT WONT START Posted: Wed May 30, 2018 12:16 pm |
Joined: Wed Jan 31, 2018 7:25 am Posts: 26 Location: Australia
hi my sport will not start after leaving it for a week or so if i use areo start it will start and run then no problem starting once it has run i have done a hole 51klm on it and the new plugs i put i are sooty black its been sitting around for a while not used it has a full tank of new pump gas as i ran out 500 meters from home i have changed the belts the starting problem has got to a stage now it wont start without areo start (either in a can) i have not checked anything yet but i think new air filter to start new oil filter and oil new plugs again if then it wont start off to the ducati workshop jim sydney australia
| Top |
Challenger392
Post subject: Re: 1988 750 SPORT WONT START Posted: Wed May 30, 2018 1:17 pm |
Joined: Sun Mar 25, 2018 6:39 pm Posts: 36 Location: Vermont,USA
Sounds like a fuel problem to me. Change/check your fuel filters. Then try again.
| Top |
Post subject: Re: 1988 750 SPORT WONT START Posted: Wed May 30, 2018 6:24 pm |
| paso grand pooh-bah |
Asuming there was a time when the bike was starting up well one main question should be has something been done to it between back then and now? I.e. is it possible the belts are not sitting correctly and are one tooth off? Since the plugs are sooty and black I'm guessing there is fuel. There are numerous possibilities. One is there's an electrical problem and the spark is too weak. So measure if you get the full voltage at the coils. Another potential cause could be that the carb's float needle valve doesn't seal and fuel is overflowing into the cylinders. Is there any strong fuel smell from the exhaust or is there backfiring after the engine started? Has the oil level increased? If you change it smell if the oil has smell of fuel. If it does fix the carb before filling up with fresh oil. Be careful using starter aid spray. Only use little of it as it will wash the oil from the cylinders.
| Top |
jimg1au
Post subject: Re: 1988 750 SPORT WONT START Posted: Sun Jun 03, 2018 11:25 am |
Put some hotter plugs in and gave the symptoms of a flooded engine eventually started and ran well leaving it for two days and will try and start again no arostart
| Top |
[ 4 posts ] |
Users browsing this forum: No registered users and 8 guests |
