ducatipaso.org • View topic - New clutch drain bolt
It is currently Thu Feb 26, 2026 2:28 am
 Post subject: New clutch drain bolt
PostPosted: Fri Jun 08, 2018 6:24 pm
Where can I buy new clutch oil drain bolt?
I can’t find it on ebey, and I don’t have a Ducati dealership.
Sagi
 Post subject: Re: New clutch drain bolt
PostPosted: Fri Jun 08, 2018 8:38 pm
Do you mean the air bleed bolt on the clutch slave?
PostPosted: Sat Jun 09, 2018 5:38 am
Yes
PostPosted: Sat Jun 09, 2018 7:31 am
it's the same as used on the brake calipers if that helps
PostPosted: Sat Jun 09, 2018 7:33 am
M10 X 1mm banjo bolt. Google it, they are readily available.
PostPosted: Sat Jun 09, 2018 8:11 am
I’m talking about that one:
I couldn’t find on ebey...
PostPosted: Sat Jun 09, 2018 6:38 pm
Hi Sagil,
I bought mine at Stein Dinse in Germany: http://www.stein-dinse.biz
They ship worldwide.
Part number 63140161A, Duc bleeder screw 08/P4 30/34 M10x1, 15mm, silver
https://www.stein-dinse.biz/Brembo/Supp ... 11167.html
Good luck.
Best regards, Ronald
PostPosted: Sat Jun 09, 2018 7:04 pm
Thanks!
I will purchase it from your links
PostPosted: Sat Jun 16, 2018 1:54 am
I guess its all in knowing the lingo Sagil , round these here parts we call, that a" bleed nipple" and I can imagine there are reasons why it aint called that in all parts of the world , but anyhow search that on ebey :wink: and you will be spoilt for choice :)
