ducatipaso.org • View topic - 750 Sport run issue
It is currently Sun Jun 21, 2026 11:44 am
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: 750 Sport run issue
PostPosted: Wed Jun 13, 2018 11:19 am
Thank for the tips! Have to measure the pump pressure. How much is the original pump pressure value?
I desided to get new fuel lines and the Holley regulator. I assume this is the item people are using? ?
Also will check the needle and float level.
PostPosted: Wed Jun 13, 2018 3:29 pm
PostPosted: Wed Jun 13, 2018 5:28 pm
PostPosted: Wed Jun 13, 2018 7:21 pm
PostPosted: Wed Jun 13, 2018 9:23 pm
As far as I know, the fuel pump of the SSie deliver 3 bar. Fuel pumps for the carburators models deliver a much lower max. fuel pressure. I believe the value is something around 0,5 bar.
Greeting Volker
PostPosted: Thu Jun 14, 2018 2:56 pm
What is the floot level hight? 42mm or more? If 42mm without gasket then no ptoblem there. Needle is ok.
Oh and my carb has those plastic floots so can’t use the same values as in weber.doc (50mm)
PostPosted: Thu Jun 14, 2018 3:05 pm
My carb is 44DCNF. Isn’t the original 40DCNF?
Edit: got too much fuel gas in my head and confused the carb type :wacko:
PostPosted: Thu Jun 14, 2018 3:25 pm
Shop Manual says 44DCNF and flaoting hight 44mm
PostPosted: Thu Jun 14, 2018 7:19 pm
PostPosted: Fri Jun 15, 2018 11:03 am
generally speaking regardless of the spec the float should be level with the carb top with the needle closed
