| It is currently Fri Jun 19, 2026 3:07 am |
[ 4 posts ] |
| Author | Message | |||||
| fasterdammit |
Joined: Wed Jan 19, 2005 12:00 am Posts: 708 Location: CNY, US model: 750 Paso year: 1988 |
| Top | ||||||
| Mc tool |
Joined: Wed Dec 05, 2007 12:35 am Posts: 1793 Location: Newzealand model: 906 Paso year: 1990 |
| Top | ||||||
| fasterdammit |
| Top | ||||||
| paso750 |
Joined: Sun Jul 18, 2004 12:00 am Posts: 5494 Location: southern Germany model: 750 Paso year: 1987 |
| Top | ||||||
[ 4 posts ] |
Users browsing this forum: No registered users and 19 guests |
| You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum |
) and yes you should tighten it just enough to seat it . As for the Y thing , a T will do but there needs to be some restriction in the return line to the tank . Some peeps use a small carb jet but just a bit of an extra long return line will restrict flow enough to do the job my return line ( on the 906 ) is about 600mm of 1/4" fuel line. Do check the float valves for leakage but if it is the float valves it more likely that there is a bit of crap jamming the valve open ...... if indeed there is actually a float issue .... sounds like its not getting enough juice and if you have just had a tutu with the fuel supply side of things it would pay to check that its getting enough pressure to the carbs , but not to much ..... hence the return line which stops the carb from seeing full pump pressure. Another fix is to dump the electric pump and go for a diaphragm type pump off a monster which runs off manifold vacuum and wont over feed the carbs, so you wont want the return line with that. Just as a thought are you sure that it running on both pots when you put it under a bit of load ( might idle ok with no load and then drop one pot when you start to let clutch out, and they can sound almost ok when running on one pot to the unfamiliar ear..........just no go power
