It is currently Mon Mar 02, 2026 3:22 am
 Post subject: Fork difference between 750 and 906 and 907ie
PostPosted: Wed Sep 19, 2018 12:50 pm
Hello Everyone,
does someone of you know the forks difference between 750 and 906 and 907ie ?
Gabriel
Paso 750
Elefant 750 Monofaro
Elefant 900 Monobraccio
Elefant 750 pure off
Indiana 650
 Post subject: Re: Fork difference between 750 and 906 and 907ie
PostPosted: Wed Sep 19, 2018 1:27 pm
as it says in the FAQs
Stanchion tube lengths:
Paso 750
left: 580 or 590mm
right: 560mm
Paso 906
left: 630mm
right: 600mm
The ones of the 907 are probably different as well. Fork spring length is also different.
The fork legs of the 750/906 are for brake calipers with 108mm mounting hole distance. The ones of the 907IE are for 40mm. Also the caliper mounts for early 907IE were lower as 300mm discs were used and later 320mm.
PostPosted: Wed Sep 19, 2018 6:44 pm
Thanks for the information!
I will save it!
Gabriel
Paso 750
Indiana 650
PostPosted: Thu Sep 20, 2018 12:09 pm
907 forks longer than 750/906, don`t know how much though.
