ducatipaso.org • View topic - Rear disc brake
It is currently Wed Feb 25, 2026 9:18 am
 Post subject: Rear disc brake
PostPosted: Tue Oct 09, 2018 10:03 am
Dear Enthusiast,
I would need a rear brake for 750 wheels.
Do I need to look for it only as Ducati Paso 750 or it is compatible with other motorcycles?
Thanks for your help!
Gab
Gabriel
Paso 750
Elefant 750 Monofaro
Elefant 900 Monobraccio
Elefant 750 pure off
Indiana 650
 Post subject: Re: Rear disc brake
PostPosted: Tue Oct 09, 2018 1:51 pm
Rear brake is the same as the 906 Paso and 750 sport (NOT the 907 !), but what do you need: disk, caliper, caliper mounting bracket .....?
Assuming you have the master brake cylinder and will buy new brake pads and brake line?!
The caliper, a Brembo P108, is relatively easy to find new or used (ebay etc.).
The disk, new, is a bit more difficult but a good second hand does the job - though you have to clean it or even sometimes you have de-rust it, which isn't to difficult with some sandpaper)
https://www.ebay.com/itm/Ducati-paso-75 ... 547?hash=i
Same with the caliper mounting bracket: relatively easy to find sevond hand, a.o. ebay
Let us know ....
PostPosted: Tue Oct 09, 2018 7:03 pm
Sorry Frank,
just the disc, for the rest I have all.
Thanks for the link but to get the disc in Italy it will cost too much.
I will look locally.
Thanks.
Gabriel
Paso 750
Indiana 650
PostPosted: Tue Oct 09, 2018 8:18 pm
No problem, if you do not succeed try Rudy. :thumbup:
PostPosted: Thu Oct 11, 2018 8:19 am
All goodmorning,
as I did not find new discs at cheap price I decided to ask to a local producer to make it for me.
I already asked to RS BIKES located in Italy several discs and for the Paso rear one he asked me 60 euro + shipping.
I checked into the web and found the following measures:
EXT diam 270mm
INT diam 139mm
CENTER HOLES at 154mm
HOLES diam 6,5mm
Is that correct? I want to be sure before to place the order.
THANKS !
Gabriel
Paso 750
Indiana 650
PostPosted: Thu Oct 11, 2018 9:07 am
The holes for the screws are 8,1mm as they are M8 bolts.
The inner diameter of 139mm seems too big. I have an adapter for a Marvic rim and it's diameter is 136mm so the disc should be only slightly larger.
PostPosted: Thu Oct 11, 2018 9:26 pm
Assume it is a stainless steel disk?
To be honest, it's quit cheap especially for a one off ..... :thumbup:
I paid for a stainless steel version 137 euro's.
