ducatipaso.org • View topic - headlight ducati 750--900 sport.
It is currently Wed Feb 25, 2026 3:41 am
 Post subject: headlight ducati 750--900 sport.
PostPosted: Sat Oct 27, 2018 4:56 pm
I need a headlight for my 900 European, I have the one of my English motorcycle, not valid to drive in Europe.
If you are in England and have the same problem, I can make a change.
If you have a European one, for sale, on your shelf, I can also buy it.
 Post subject: Re: headlight ducati 750--900 sport.
PostPosted: Thu Nov 01, 2018 4:21 am
Gday mate, if the English light is the same as Australian I could do a swap as I only have the European unit, if that would help, cheers
PostPosted: Thu Nov 01, 2018 7:49 am
Just in case you do not succeed: a new one (CEV 287 288).
https://www.ebay.es/itm/FARO-ANTERIORE- ... 2855320827?
Good luck! :thumbup:
PostPosted: Thu Nov 01, 2018 7:58 am
Please do check the CEV numbers on your headlight, to be sure it's the correct one.
PostPosted: Thu Nov 01, 2018 8:32 am
Frank, that headlight for the later 900SS does not fit the 89/90 900SS which used the same one as the 750Sport and F1.
PostPosted: Thu Nov 01, 2018 9:03 am
Anyone know the correct CEV numbers for the aussie headlight, cheers
PostPosted: Thu Nov 01, 2018 9:48 am
Just have a look at the parts catalog :truck:
067038200 is for rhs traffic
067038210 for lhs
PostPosted: Thu Nov 01, 2018 9:59 am
If someone has a clear picture of the headlight with brand (CEV, Carrello etc.) and numbers or even the dimensions I can try to find out whether it was also used for other vehicles (Fiat?).
Production numbers were so low in the mid eighties, chanses are it was not a "Cagiva special".
If I could get the dimensions also it would be helpfull.
Just let me know if you want me to look for a source .....
I hardly know the 900ss but I've done this exercise a few times for my Bimota and some Cagivas a few years ago.
First items I search for/buy when I have a restoration project are all items related to lights and rubber parts.
PostPosted: Thu Nov 01, 2018 10:46 am
Then I will go to my garage, I will try to photograph the two lighthouses.
I've tried it before, but the numbers are not clearly seen by the reflection of the crystal.
I'll try again.
PostPosted: Thu Nov 01, 2018 6:23 pm
PostPosted: Thu Nov 01, 2018 6:25 pm
PostPosted: Thu Nov 01, 2018 6:38 pm
PostPosted: Thu Nov 01, 2018 11:05 pm
So that I understand it correctly: do you need a CEV 304 or a CEV 364?
The CEV 304 I see new ones on ebay, no 364 though ....
PostPosted: Fri Nov 02, 2018 4:22 pm
PostPosted: Thu Nov 15, 2018 9:59 am
