It is currently Sun Jun 21, 2026 11:55 am
Post new topic Reply to topic  [ 509 posts ]  Go to page Previous  1 ... 20, 21, 22, 23, 24, 25, 26 ... 34  Next
PostPosted: Mon Nov 19, 2018 11:42 am
Thanks mate, but yeah these are just always a little different so some initial 'shit they won't fit' to some tweaking and now I'm pretty happy how they sit, need to fit a smaller battery to avoid hitting cable bracket on fcr's, haven't got the new throttle/ cable's yet but fingers crossed
PostPosted: Mon Nov 26, 2018 11:45 am
I got the throttle and cables but they look all wrong to me , they have a 90 degree metal elbow where they attatch to the carburetor bracket where I would expect a straight fitting, also seem too long , anyone got any pics of their setups much appreciated
PostPosted: Mon Nov 26, 2018 3:35 pm
90 degrees normal.
http://bradthebikeboy.blogspot.com/2011 ... ucati.html
PostPosted: Mon Nov 26, 2018 4:26 pm
http://ducatimonsterforum.org/index.php?topic=36762.0
PostPosted: Tue Nov 27, 2018 4:27 am
I have been advised that I have carburetor facing wrong way for a start, back to the drawing board, thanks for the help there guys and pics , I don't want to move any electrics, battery , I may have created myself some headaches
PostPosted: Tue Nov 27, 2018 9:08 am
Feeling very stupid and lucky I just got home and turned fcrs around , the bent battery stays are still working in my favor and all seems good, I'll try the old standard size battery next and hopefully no more soft hammer work necessary on the tray/ stays
PostPosted: Tue Nov 27, 2018 9:09 am
PostPosted: Tue Nov 27, 2018 10:51 am
It all fits although tight , could gain a little more clearance on carbs but so far no damage to powder coating so reluctant to do so unless imperative, just trying to suss the best route for cables which I'm oiling now , not sure on filter system yet as I have no airbox and rather a less cluttered setup , stress levels have come down a little
PostPosted: Tue Nov 27, 2018 1:20 pm
PostPosted: Tue Nov 27, 2018 9:33 pm
model: other
I've been following this thread since you started it, and it certainly has been an interesting journey.
Mine was sold to a site member in 2014 or 15, but the attached picture was how it was setup when I bought it from Old Gold Motorcycles.
Mixture screws were a bit challenge to get too, but aside from that everything functioned as it should, was mainly a track bike, but would fit a set of Oiled Uni Filters for road use.
Just a different way of approaching it.
PostPosted: Thu Nov 29, 2018 4:29 am
Yeah 851 , mine had the mikunis and oil/ unis on it originally, I have it all fitted but not sure on adaptors for uni filters , also maybe shorter fuel inlets to fit bigger filters, ? I now have the throttle and cables setup
PostPosted: Thu Nov 29, 2018 10:44 am
Having another look I'm guessing it's not even possible to use shorter inlet stubs with the dual carbs
PostPosted: Thu Nov 29, 2018 10:55 am
I have the cables running over the left side of the old battery ,through the top triangle left side of head stem then below ignition barrel to throttle, I will have to disconnect the throttle again to remove old battery and replace with new, yes I'm definitely muddling my way through it but determined to get a good result
PostPosted: Thu Nov 29, 2018 10:58 am
PostPosted: Thu Nov 29, 2018 10:42 pm
model: other
The adapters should be available from the Keihin people in Adelaide, but they come at a fairly serious bit of money, bought mine in 2012 with the O Rings required and they were $155 or so then.
Then again mine were not joined.
