It is currently Fri Nov 14, 2025 2:23 am
[ 2 posts ] |
| Author |
dennist
Post subject: Timing Belt Replacement Recommendations Posted: Sat Dec 01, 2018 4:31 am |
Joined: Sun Feb 22, 2009 4:55 am Posts: 64 Location: Oregon City, Oregon USA
This is for you current or past Ducati mechanics or knowledge owners. 1992 907ie, professionally serviced 6 years ago with valve adjust, new belts and a bunch of other service items completed. Bike has been ridden approximately 500-800 miles since then (6 years) and always stored in enclosed garage in fair weather climates. I am not inclined to replace the belts now since no use of the bike, no heat cycles, stretching and enclosed by cover of belts on engine. New belts sit for years on dealers shelves then installed as new belts. Not much different than sitting in an unused bike. Under these conditions I don't feel the combination of bad elements exist to require replacing timing belts at this time. Was thinking belts would be good for another 3-4K miles. Am I all wet or on the right track. Bike all original, never abused and has 15k miles on it. Thanks for your opinions.
| Top |
Sheff928
Post subject: Re: Timing Belt Replacement Recommendations Posted: Sat Dec 01, 2018 9:15 am |
Joined: Tue May 20, 2014 3:04 pm Posts: 22 Location: UK
I'd be inclined to do what you think. I'd put the bike in gear every so often and move it forward without starting it so that the belts get moved around tight radii, but I wouldn't end up doing that regularly. Belts are long lasting as long as accurately fitted in the first place. I ran my Porsche 928 on a timing belt 17 years old before I ran out of nerve and changed it. It still looked perfect...
_________________ Kindest regards, Kevin ----------------------------- 907ie 1992 ST4s 2002 750SSie 2002 Cagiva Gran Canyon 1999 Norton Commando 750 1971
| Top |
[ 2 posts ] |
Users browsing this forum: Google [Bot] and 4 guests |
