It is currently Thu Nov 13, 2025 12:01 pm
[ 4 posts ] |
| Author |
dennist
Post subject: Fork Oil Replace Posted: Sun Dec 02, 2018 6:06 am |
Joined: Sun Feb 22, 2009 4:55 am Posts: 64 Location: Oregon City, Oregon USA
Want to change fork oil/fluid. Looks like most other bikes in that you drain fluid, pump forks to get it all out, support bike so when you take fork caps off springs do not fly up and front end drops, pour in manual suggested weight and quantity of oil, screw caps back in and done, right? Anything particular on these 907's in doing that? Could not find a thread on procedure on forum and Workshop Manual listed on this site does not show it. It does refer to pages 19a & 20a for changing oil with forks in place but pages are missing when downloaded. Thanks for your help.
| Top |
Post subject: Re: Fork Oil Replace Posted: Sun Dec 02, 2018 10:46 am |
| paso grand pooh-bah |
There's a M1R manual for download and the 907IE wsm is only a supplement of the 906 wsm. Everything that is missing you will find there. All in all it's as you described.
| Top |
dennist
Post subject: Re: Fork Oil Replace Posted: Sun Dec 02, 2018 2:39 pm |
I just found the M1R Manual that came with my bike in folder I had overlooked from previous owner. Original complete Manual for front forks. Very helpful. Thanks for heading me in that direction.
| Top |
du907
Post subject: Re: Fork Oil Replace Posted: Tue Dec 11, 2018 12:36 am |
Joined: Fri Jul 08, 2005 12:00 am Posts: 336 Location: Winston-Salem, N.C. USA
What I usually do is when filling the forks, I put in a little extra fluid. I then take a piece of copper tubing (because it is stiff and will hold its shape/length) that I have made to the length of the recommended air space and using a syringe pull out the extra fluid until it doesn't pull out any more fluid. You are then left with the proper amount of fluid in the forks, at least close enough. du907
| Top |
[ 4 posts ] |
Users browsing this forum: No registered users and 2 guests |
