It is currently Sat Feb 28, 2026 2:15 am
[ 11 posts ] |
| Author |
Rickman
Post subject: Broken Neutral Switch Posted: Thu Dec 27, 2018 2:48 pm |
Joined: Sat Sep 15, 2018 1:12 am Posts: 13 Location: USA
| Top |
Duc906
Post subject: Re: Broken Neutral Switch Posted: Fri Dec 28, 2018 7:58 am |
Joined: Mon Mar 30, 2009 7:59 pm Posts: 269 Location: Australia
| Attachments: |
| Top |
Rickman
Post subject: Re: Broken Neutral Switch Posted: Fri Dec 28, 2018 2:37 pm |
| Top |
Derek
Post subject: Re: Broken Neutral Switch Posted: Fri Dec 28, 2018 3:52 pm |
| paso grand pooh-bah |
| Top |
Rickman
Post subject: Re: Broken Neutral Switch Posted: Sun Dec 30, 2018 2:11 am |
| Top |
Derek
Post subject: Re: Broken Neutral Switch Posted: Sun Dec 30, 2018 10:53 am |
| Top |
Rickman
Post subject: Re: Broken Neutral Switch Posted: Sun Dec 30, 2018 4:33 pm |
| Top |
Post subject: Re: Broken Neutral Switch Posted: Sun Dec 30, 2018 7:04 pm |
Derek has a point but if the switch has broken off in position B and only the hollow & threaded part of the switch is left, the spring may have already jumped/fallen out. If not I'd probably remove it and insert a little bit of silicone sealant to secure the plunger from falling into the engine. If the threaded part doesn't turn it is possible you screwed in the switch too far and there's pressure on it in which case putting the engine into gear may help. Once it's loose you may be able to get it out with the eraser side of a pencil or something similar that has grip. If it's sitting tight and depending on how long the spring was, inserting a torx key may also be an option. You could also find a long thin bolt and glue it in. Best to do the last two when the gearbox in is neutral. I'm still wondering why the switch snapped off. If you're still using the old one how thin was the new copper washer you used? The original one is 1.5mm.
| Top |
Post subject: Re: Broken Neutral Switch Posted: Mon Dec 31, 2018 11:50 am |
_________________ Gert
907 I.E. -91 M900 -97 MTS 1100s -07
| Top |
Rickman
Post subject: Re: Broken Neutral Switch Posted: Wed Jan 02, 2019 1:05 am |
| Top |
Duc906
Post subject: Re: Broken Neutral Switch Posted: Thu Jan 03, 2019 7:15 am |
Good outcome
| Top |
[ 11 posts ] |
Users browsing this forum: No registered users and 36 guests |
