ducatipaso.org • View topic - Broken Neutral Switch
It is currently Tue Mar 03, 2026 12:20 am
 Post subject: Broken Neutral Switch
PostPosted: Thu Dec 27, 2018 2:48 pm
 Post subject: Re: Broken Neutral Switch
PostPosted: Fri Dec 28, 2018 7:58 am
PostPosted: Fri Dec 28, 2018 2:37 pm
PostPosted: Fri Dec 28, 2018 3:52 pm
PostPosted: Sun Dec 30, 2018 2:11 am
PostPosted: Sun Dec 30, 2018 10:53 am
PostPosted: Sun Dec 30, 2018 4:33 pm
PostPosted: Sun Dec 30, 2018 7:04 pm
Derek has a point but if the switch has broken off in position B and only the hollow & threaded part of the switch is left, the spring may have already jumped/fallen out. If not I'd probably remove it and insert a little bit of silicone sealant to secure the plunger from falling into the engine. If the threaded part doesn't turn it is possible you screwed in the switch too far and there's pressure on it in which case putting the engine into gear may help. Once it's loose you may be able to get it out with the eraser side of a pencil or something similar that has grip. If it's sitting tight and depending on how long the spring was, inserting a torx key may also be an option. You could also find a long thin bolt and glue it in. Best to do the last two when the gearbox in is neutral.
I'm still wondering why the switch snapped off. If you're still using the old one how thin was the new copper washer you used? The original one is 1.5mm.
PostPosted: Mon Dec 31, 2018 11:50 am
https://youtu.be/dJfkCj3FWBs
PostPosted: Wed Jan 02, 2019 1:05 am
PostPosted: Thu Jan 03, 2019 7:15 am
Good outcome :thumbup:
