ducatipaso.org • View topic - Charging problem...no kidding....
It is currently Thu Nov 13, 2025 4:19 am
 Post subject: Charging problem...no kidding....
PostPosted: Tue Jun 04, 2019 11:27 pm
Intermittant battery dies....charging 13.2 or so in the shop...half hour of riding almost kills the battery..no charge light..yellow wires fixed last year so, are we still using the shendengen regulator?...or are there better options....thank you so much..
92 907 i.e.
2016 F6B
2001 MG Jackal
1980 XS Eleven/1960 Watsonian sidecar
1974 Norton Commando/Factory Production Race
 Post subject: Re: Charging problem...no kidding....
PostPosted: Tue Jun 04, 2019 11:29 pm
I am going to put a digital voltmeter in....hate not knowing whats going on.....
92 907 i.e.
2016 F6B
2001 MG Jackal
PostPosted: Thu Jun 06, 2019 2:53 pm
Shindengen is good.
PostPosted: Thu Jun 06, 2019 5:16 pm
Not exactly sure whats going on with your bike, but after you sort it out go to this site and buy the upgrade. The kit these guys supply is worth every penny.
I have had my engine balanced, blueprinted, heads ported, etc. and the compression is up and well it's a stout engine. Was hard to get it started and the battery was always low. Put this upgrade on the bike and it kicks off immediately, no dragging, no whining, hit the starter button and it's running. Great product that works.
https://motolectric.com/makes/ducati.html
Bryon
Oh, clean up your grounds, check the wires you where talking about and see if they are getting hot and deforming.
PostPosted: Fri Jun 07, 2019 12:33 am
92 907 i.e.
2016 F6B
2001 MG Jackal
PostPosted: Fri Jun 07, 2019 4:48 pm
Is this a new issue or did you have it already before the regulator was replaced? Or in short, is the regulator wired correctly? ;)
PostPosted: Tue Jun 18, 2019 12:51 am
92 907 i.e.
2016 F6B
2001 MG Jackal
PostPosted: Tue Jun 18, 2019 7:39 am
Even 13.6V is a bit low. You should really be seeing 14.0V + at over 2,000 rpm.
I have a Shindengen FA020H and get around 13.6V at idle and a steady 14.2V above 2,000 rpm.
PostPosted: Tue Jun 18, 2019 7:31 pm
92 907 i.e.
2016 F6B
2001 MG Jackal
PostPosted: Tue Jun 18, 2019 8:06 pm
Whats the difference between the fa020h and fh020aa.....is it just the charge light?
92 907 i.e.
2016 F6B
2001 MG Jackal
PostPosted: Thu Jun 20, 2019 8:01 am
Sorry, I probably have you the wrong Shindengen number. I was writing from memory, I'm in Turkey right now. It is a MOSFET regulator with no provision for a charge light.
PostPosted: Thu Jun 20, 2019 12:12 pm
Everything you need to know
PostPosted: Sat Jun 22, 2019 7:47 pm
So I went with the fh020aa and all is good in my Paso world, for now....14.5 at 2k....steady....
Tnx for everyones input......
92 907 i.e.
2016 F6B
2001 MG Jackal
PostPosted: Sun Jun 23, 2019 7:36 am
Good to hear. Thanks for the feedback :thumbup:
PostPosted: Sun Jun 23, 2019 9:33 am
I also put a small volt meter just under the coolant guage, I like it and I think I'll use it on my other old bikes. Nice to know whats going on....amazon $12.....
92 907 i.e.
2016 F6B
2001 MG Jackal
