It is currently Tue Oct 27, 2026 11:16 am
[ 9 posts ] |
| Author |
daredevil
Post subject: fuel pumps Posted: Tue Jul 30, 2019 3:50 pm |
Joined: Fri Nov 20, 2015 8:04 am Posts: 2 Location: Italy
with this fuel pump I solved most of the problems of my ducati paso now consumes less electricity the right pressure of the gas comes and do not flood the ducts and the spark plug anymore ... even if it does not have the original housings but must be mounted with a big clamp is really worth mounting it .... :-D
Huco 133010 (found it on ebay)
| Top |
Alfaman
Post subject: Re: fuel pumps Posted: Thu Aug 01, 2019 7:54 pm |
Joined: Fri Apr 12, 2019 1:45 pm Posts: 6 Location: USA
thanks for the referral. Is this pump close in size to the stock item?
-Steve
| Top |
daredevil
Post subject: Re: fuel pumps Posted: Fri Aug 02, 2019 6:50 am |
this pump is larger than the original one at least three times ... you have to mount it vertically by attaching it to the petrol pipes and anchoring it with a beautiful and large clamp to the upper supporting metal frame for the fairing and resting on the descending beam of the frame
| Top |
Madfiber
Post subject: Re: fuel pumps Posted: Sat Aug 17, 2019 1:02 am |
Joined: Mon Aug 05, 2019 5:50 pm Posts: 2 Location: USA
I noticed that my bike (1988 750 paso) has 8.5 volts going to the pump and not 12 volts. Will that work ok with this pump your suggesting? I need a new pump myself asap.
| Top |
Post subject: Re: fuel pumps Posted: Sat Aug 17, 2019 9:02 am |
| paso grand pooh-bah |
| Top |
Madfiber
Post subject: Re: fuel pumps Posted: Sun Aug 18, 2019 1:57 pm |
Ok, thank you. I'll check it out at once.
| Top |
mark999.multi
Post subject: Re: fuel pumps Posted: Thu Sep 05, 2019 9:00 am |
Joined: Mon Aug 26, 2019 1:56 pm Posts: 42 Location: Italy
I have installed a vaacum fuel pump from a Monster 750.... To the end the pump work, it's the cheeper solution but.... the only problem it's when you stop the Paso for a long time.... When you try to restart it, need a lot of attemps before start the motor..... For the moment i will keep this solution, also because i use my Paso sometimes just for short drive.... but in a future i would like replace the electric pump as a original.... (price and availability allow...!)
_________________ Suzuki GSX-R 600 '00 (ex) Ducati 999 '05 only track Cagiva Elefant 750 '95 (ex) Ducati Multistrada 1200S Sport 2012 (ex) Ducati Multistrada Enduro 2016 Ducati Paso 750 '90
| Top |
Post subject: Re: fuel pumps Posted: Thu Sep 05, 2019 9:21 am |
mark999 if the bike is parked for such a long time that the fuel in the carbs' float chamber is evaporated you will experience the same with an electric fuel pump. Install your current pump in a lower position (lower than the tank's petcock).
| Top |
mark999.multi
Post subject: Re: fuel pumps Posted: Thu Sep 05, 2019 1:10 pm |
| Top |
[ 9 posts ] |
Users browsing this forum: No registered users and 10 guests |
