ducatipaso.org • View topic - Sprocket cover interchangeable?
It is currently Wed Feb 25, 2026 12:29 am
 Post subject: Sprocket cover interchangeable?
PostPosted: Tue Oct 01, 2019 1:55 am
750 and 906 Pasos have different part numbers for this part.
But can one from a 750 fit a 906, or is there an important difference?
 Post subject: Re: Sprocket cover interchangeable?
PostPosted: Tue Oct 01, 2019 10:59 pm
Some times the quickest way to find out is to go to good ole eBay ( or elsewhere ) and see if you can't view pix of parts for sale. I thing the 750 and the 906 motor are based on different crankcases so it probly is different
PostPosted: Wed Oct 02, 2019 8:45 am
The cover on the 500 and 600 Pantah engines are certainly different. I'd assume that the 750 Paso engine which is based on the Pantah engine is also different.
PostPosted: Wed Oct 02, 2019 4:34 pm
PostPosted: Sun Oct 06, 2019 9:02 am
The Paso 906 here has the clutch slave cylinder on the right.
So, a Paso 750 sprocket cover should be OK.
Thank you for the info.
PostPosted: Tue Oct 08, 2019 11:19 am
PostPosted: Tue Oct 08, 2019 3:58 pm
Ken, you're right. My bad.
PostPosted: Thu Dec 12, 2019 6:07 am
The sprocket cover was described as fitting Paso 750 and 906.
It fits perfectly, with a cutout for the dummy clutch slave cylinder.
