It is currently Thu Oct 29, 2026 12:45 am
[ 9 posts ] |
| Author |
Jorian
Post subject: Timing belts Posted: Mon Oct 07, 2019 9:29 am |
Joined: Wed Sep 25, 2019 6:37 am Posts: 24 Location: Australia
Anything special about these, or will any good brand of the correct size be OK?
| Top |
angelix
Post subject: Re: Timing belts Posted: Mon Oct 07, 2019 4:18 pm |
Joined: Thu Nov 29, 2007 2:38 am Posts: 338 Location: UK
I am afraid you will have to go for the OEM ones, Gates makes them specificly for Ducati and none of the other brands will fit properly.
There is ONLY one alternative I know of and has been developed by Chris @ California CycleWorks, they are good and cheaper that OEMs, but I am not sure they have the profile version used on the old Pantah engines.
Since you are looking for a replacement, I would source from Ebay a set of Camshaft pulleys from the newer versions of the V2 engine (models post MY2000) that have a better belt profile and are ADJUSTABLE, then you can eiyther fit the OEM belts of the California Cycleworks...
| Top |
Derek
Post subject: Re: Timing belts Posted: Mon Oct 07, 2019 5:24 pm |
| paso grand pooh-bah |
California Cycleworks do Exactfit belts for the bikes that use square profile tooth belts. You need belt TBF1 which fits; Ducati 750 F1 All models Ducati 400 F3 All models Ducati Indiana 350 Ducati Indiana 650 Ducati Monster 400 (1997 and older) Ducati Monster 600 (1997 and older) Ducati Monster 750 (1997 and older) Ducati Pantah 350 Ducati Pantah 400 Ducati Pantah 500 SL Ducati Pantah 600 SL Ducati Pantah 650 Ducati Pantah 750 Ducati Paso 750 Ducati Supersport 750 (1997 and older)
Bimota DB1
Cagiva Elefant 350 Cagiva Elefant 650 Cagiva Elefant 750 Cagiva Alazurra 350 Cagiva Alazurra 650
They are £47.95 a pair from the UK distributor.
| Top |
Duc906
Post subject: Re: Timing belts Posted: Tue Oct 08, 2019 10:53 am |
Joined: Mon Mar 30, 2009 7:59 pm Posts: 269 Location: Australia
| Top |
Post subject: Re: Timing belts Posted: Tue Oct 08, 2019 4:10 pm |
There's also Flennor.
Derek, are you sure the TBF1 are right and not the TB900? The 906 belts are the same as the ones of the 907IE.
angelix, "I would source from Ebay a set of Camshaft pulleys from the newer versions of the V2 engine (models post MY2000) that have a better belt profile" What's different in the profile? Some belt fitment lists, list the 906 but also the ST2 -2003 or the MH. If the profile was different and the cam pulleys would have to be swapped, the driving pulleys would have to be changed as well.
| Top |
Derek
Post subject: Re: Timing belts Posted: Tue Oct 08, 2019 5:49 pm |
| Top |
Jorian
Post subject: Re: Timing belts Posted: Wed Oct 09, 2019 1:47 am |
The brand Flennor has been mentioned. Do others agree this a safe choice? Someone in Germany has service kits that include them, as well as filters etc. It would be convenient to get the complete kit.
| Top |
smartino67
Post subject: Re: Timing belts Posted: Wed Oct 09, 2019 6:09 am |
Joined: Thu Mar 05, 2015 2:05 pm Posts: 6 Location: Italy
| Top |
Mirinn
Post subject: Re: Timing belts Posted: Sat Oct 19, 2019 9:32 am |
Joined: Fri Oct 27, 2017 1:47 pm Posts: 34 Location: Czech Republic
I've been using Dayco belts for several years in more Ducati models, and so far there has been no problem. We are much cheaper than original belts
| Top |
[ 9 posts ] |
Users browsing this forum: No registered users and 9 guests |
