ducatipaso.org • View topic - Strange rear light lens?
It is currently Thu Apr 23, 2026 10:39 am
 Post subject: Strange rear light lens?
PostPosted: Fri Mar 10, 2006 6:34 pm
PostPosted: Fri Mar 10, 2006 7:36 pm
-Craig
PostPosted: Fri Mar 10, 2006 7:55 pm
PostPosted: Sat Mar 11, 2006 10:15 pm
Finnpaso, that is the identical shape to the Euro shaped lense... the shallow red thing at the bottom houses the clear plastic used to illuminate the number plate.
hope the flu gets better... VitC halves it's duration btw.
PostPosted: Sun Mar 12, 2006 3:23 pm
It CAN be, that i have too much fever still ! But looks little different that rear light/brake part of lens (higher).... Btw, i have seen in internet long time ago some samekind lens in some Paso "prototype", or something, like that. That came to my mind just.... anyway, this is not so important, but i only noticed, that center part of lens is higher, than normal Paso lens.... :confused: I am virgin, so all thiskind things burn my brains very much :laugh:
PostPosted: Mon Mar 13, 2006 1:11 am
PostPosted: Mon Mar 13, 2006 6:51 am
OK, well maybe i have a prototype lens also because mine looks like this...
draw your own conclusions...
PostPosted: Mon Mar 13, 2006 9:13 am
That is a very nice tail light. I wish mine was in such good shape. It is made by CEV the same as the front indicators. Is yours the same brand?
PostPosted: Tue Mar 14, 2006 7:15 pm
PostPosted: Tue Mar 14, 2006 8:37 pm
PostPosted: Wed Mar 15, 2006 7:51 am
Seems, that Ducati have still, or make still those front blinker lenses, but very many USA guys want to change "all red"Usa modell rear taillight lens to Euro modell with yellow blinkers, that they can get rid of those awfull looking rear turn signals(and put bulb holdwers inside taillight).... Pasos styling is designed with ONLY blinkers integrated to rear light system :thumbup:
PostPosted: Wed Mar 15, 2006 8:12 am
I have an all red tail light but the blinkers are in it. I waould also like orange blinkers. The internals are all set up just got the wrong lense.
PostPosted: Wed Mar 15, 2006 7:02 pm
There are (at least)2 different rear lights, those with blinkers(EU modell) and without inside blinkers(USA modell) and fitting to lens is totally same, so "You" can change lenses easily, without any modifications.
As normally, we Europeans want "USA all red" lens, cause its quite rare here and surely You want with yellow blinkers, cause its rare there in NZ and Australia. Both lenses have same totally same numbers stamped, so easy to change lenses, BUT "your" country rules makes, WHAT is legal and what is not legal. Here in Finland many USA cars imported to Finland have red blinkers, and they say, that its ok, if "all red" blinkers have those "EU needed numbers"(like Paso lens have luckily!!!), but surely it depends about local rules... and here polices seem to NOT have enough time to check such things in traffic, so i think, no any broblem here to use all red Usa style lens in Paso. But better fist check thing about local rules :thumbup:
Btw, i changed just my "Euro lens" to "USA lens" with one guy here in this site...
