It is currently Sat Jun 20, 2026 1:13 pm
Post new topic Reply to topic  [ 509 posts ]  Go to page Previous  1 ... 22, 23, 24, 25, 26, 27, 28 ... 34  Next
PostPosted: Fri Jun 21, 2019 9:04 am
Yeah I use my phone, I think I may need to close maybe shutdown this membership and try start again, all turned to crap when I did NBN switch with my mobile phone network, pretty annoying, this is a great forum
PostPosted: Sun Aug 18, 2019 2:18 am
Just waiting for gauges to return from speedline instruments in perth for 2nd time as I had to replace the reset shaft on speedo and also refit new satin black powder coat bezels, chrome just wasn't right, oil cooler/ lines/ headlight/ wiring can then be connected and I'm off to protwins for Justin to work his magic. Soon as she's out the door I will start the painting process and when she returns I will be leaving her in my lounge till the painting is done, good times, on target to finish for xmas, been a long time coming but getting there, Rob.
PostPosted: Sun Aug 18, 2019 2:21 am
PostPosted: Sun Aug 18, 2019 2:23 am
Well this is good, I've just closed my Facebook account and for the first time I can post pics again, not sure if coincidence or what but certainly happy days
PostPosted: Tue Nov 05, 2019 3:41 am
Still moving along , clutch out again though as the paint on the cover was cracking, too many coats,!, nearly back together, life is getting in the way a bit, still on track to start up before xmas
PostPosted: Tue Nov 05, 2019 10:23 am
Just about to tighten the clutch control/ spring retainer and second guessing whether you tighten down to the posts, ie far as you can go, or you measure and set somewhere in between, learning ,, thanks for your interest cheers
PostPosted: Tue Nov 05, 2019 10:30 am
Not sure how or why I managed to post this pic but I will definitely be posting pics of this bike till its finally up and running, your input / continuing interest will be rewarded with all the painting and prep just need to sort out this pic uploading problem
PostPosted: Tue Nov 05, 2019 10:35 am
That's a pretty old pic, guages bevels now satin black powdercoat, ignition decal , k + N soup cans, and bits , new grips etc
PostPosted: Sat Nov 09, 2019 7:19 am
Just finished the clutch cover replacement, this original cover came up well paintwise, pretty happy with the way it all went, definitely learn more when you have to repeat processes, haha its happened a few time with me on this bike
PostPosted: Sat Nov 09, 2019 8:03 am
PostPosted: Sun Nov 10, 2019 12:05 am
PostPosted: Sun Nov 10, 2019 8:40 am
PostPosted: Fri Nov 22, 2019 1:40 am
Thanks for the update and photos! Great carpet. :^)
PostPosted: Sat Nov 23, 2019 2:26 pm
PostPosted: Sat Nov 23, 2019 2:30 pm
Shes off the bench and standing on her own albeit with the shitty original sidestand, I have another longer stand but needs some modifications to clear the exhaust, off to Justin next Saturday , happy days
