It is currently Thu Apr 23, 2026 1:38 pm
Post new topic Reply to topic  [ 509 posts ]  Go to page Previous  1 ... 23, 24, 25, 26, 27, 28, 29 ... 34  Next
PostPosted: Sun Nov 24, 2019 9:58 pm
PostPosted: Sun Nov 24, 2019 9:59 pm
PostPosted: Fri Nov 29, 2019 7:23 am
PostPosted: Fri Nov 29, 2019 7:26 am
First outing in a while, you beauty off to protwin tomoz, yeeha
PostPosted: Fri Nov 29, 2019 7:47 am
PostPosted: Mon Dec 02, 2019 6:14 pm
The bike is getting better and better :thumbup:
Interesting that the thread pattern of the front and rear tire is reversed.
PostPosted: Mon Dec 02, 2019 10:15 pm
Yeah I know, but its correct according to rotation marks,a few have mentioned it, may be start up this week bar the paintwork
PostPosted: Tue Dec 03, 2019 10:04 am
PostPosted: Thu Dec 05, 2019 10:56 am
Yep I wreckon you're onto it, I bought the paint the other day,took the all the bodywork to graphics place today on recommendation from the guys I get the paint off, so things are still moving in the right direction . Setting up the recently acquired single seat piece and how to fabricate the backrest piece,I'm planning to reglass/ bog all the predrilled fixings and then redrill as most are pretty flogged out, bit of prep needed but if I nail that I've got half a chance of a pretty good paintjob
PostPosted: Fri Dec 13, 2019 5:04 am
Just starting the paint preparation process as I know it, 240 wet/ dry to remove clearcoat,decals, in the case of the fairings now I'm removing the white over a full coat of red then the red to end up with mainly grey/ originally primer, on fibreglass, careful not to expose fibres as they are later hard to get rid of, then some fiberglass repair/ strengthening on the back of panels and finish with car filla on the finish side, I've been standing this panel for a good hour and a long way to go
PostPosted: Thu Dec 19, 2019 12:18 pm
PostPosted: Thu Dec 19, 2019 12:20 pm
PostPosted: Thu Dec 19, 2019 12:23 pm
PostPosted: Thu Dec 19, 2019 12:25 pm
PostPosted: Thu Dec 19, 2019 12:46 pm
Lots of block sanding with 240 wetdry, good few hours work, I used the orbital on the right side fairing which made it easier getting the clear coat and old decals off, those 2 panels are nearly ready to prime, just need to plug away , hope to pick the bike up from the shop tomoz, also the decals, happy days
