ducatipaso.org • View topic - Hi from Italy!!
It is currently Fri Feb 27, 2026 2:45 pm
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Hi from Italy!!
PostPosted: Mon May 04, 2020 9:41 am
Hey Marco,
I use Officine08 myself regularly (been there once on my way to Pisa, but they were closed :oops: ), in particular they have a lot of "wear and tear" parts for older Italian motorcyles (rubbers etc., the Ariette stuff).
As said, let's see how it goes with your dashboard (intriguing :smoke: ), the mounting (bracket) of the mechanical petrol pump etc.
But yours seems to be in a better condition than most I've seen (the previous owner also tried to fix the saddle neatly, like that - I personally love the original color red).
By the way: that aluminium plate used for the electrics is a typical Tamburini item (if you have ever seen the "old" Bimota's (pre DB1) you'll understand).
He always got annoyed when he saw the electrical parts crammed together like some kind of "pasta frutti di mare" :lol: .
I was once at CRG in Rimini (unfortunately after his death) there everything was super arranged, no chaos there!
And let me know the mileage of your Paso, just curious.
PostPosted: Mon May 04, 2020 11:31 am
Suzuki GSX-R 600 '00 (ex)
Ducati 999 '05 only track
Cagiva Elefant 750 '95 (ex)
Ducati Paso 750 '90
PostPosted: Mon May 04, 2020 11:53 am
this is how look now the electric panel.....
I have another question....
I have also a 2004 Ducati 999 to which I have just replaced the rear mono shock absorber with a MUPO EVO, more suitable for track use ..... now I have the original SHOWA shock installed on the 999 which advances ..... according to you, with the due tricks, it could be mounted on the Paso since the original one seems quite worn?
Ducati Paso 750 '90
PostPosted: Mon May 04, 2020 12:50 pm
Hi Marco,
Honestly? I doubt it (ordered a brand new tailor made one for my Paso, but that's more out of habit).
A few things you should check: distance eye-to-eye of the 999 shock, spring stiffness and if the "piggy back" fits your Paso frame.
I see K80, if that is for the spring stiffness 80kg/cm then that is fine.
The eye-to-eye of the Paso should be 367mm.
But first look which brand of shock you have, a few were delivered with an Ohlins (worth knowing: the Ducati Paso 750 was de first production motorcycle for the road with standard an Ohlins shock).
On the right side of the frame under the cover directly next to the battery, you will find the adjuster for the spring pretension, here you can see if it is a Ohlins or not (sticker).
Due to the relation between Cagiva (motorcross worldchampionship) and Ohlins for their competition bikes.
After a few hundred Ducati changed the brand for Marzocchi (nice but no were near as nice as the Ohlins).
If you have an original Ohlin, I strongly suggest to service that one (the Ohlins shock was very successful on the Paso and much appreciated by the trade press).
Love your 999 bye the way (not appreciated as it should - like the Paso) :thumbup:
Ciao,
PostPosted: Mon May 04, 2020 1:17 pm
Ducati Paso 750 '90
PostPosted: Tue May 05, 2020 8:00 am
Hi guys.....
about dashboard this morning i found this on Ebay.uk:
what you think? it's reasonable? only for fix the dashboard box.....
Ducati Paso 750 '90
PostPosted: Tue May 05, 2020 10:13 am
And the tacho and speedo inserts shown below. If you dont I will .
PostPosted: Tue May 05, 2020 10:59 am
Marco,
I personally think that it is usually that part, that is in order (on the other hand, it is not very expensive - if you need it).
If you clean the original dashboard gently and at ease, it usually looks a lot better, similar to the eBay article. :thumbup:
The perspex front suffers the most from time (and sunlight).
The meters themselves also can get a bit stiff over time (period of prolonged standstill).
A new (906/907) dashboard is available NOS for about 500 euros. :wacko:
I bought such a new (NOS) 2 years ago, only the Paso 750 has an oil temperature gauge instead of a water temperature gauge so I have to convert it someday.
But even with the "new" dashboards, the perspex has become a bit more brittle (but nicely scratch-free and clear). :huh:
Oh yes, Gerhard (Paso750) has experimented a lot with LED dashboard lights (he is German so that so that means it's been done very precisely and almost scientifically - take advantage of it). :beer:
If you like that kind of things, you should do that now that you have already opened the dashboard.
viewtopic.php?f=1&t=6585&hilit=led+dashboard
Keep us informed!
Il tempo è bello, puoi uscire di nuovo, quindi guida il tuo Paso)!
PostPosted: Tue May 05, 2020 11:52 am
Wow what a job!!
For sure now you give me a idea to occupy my free time!
He make a incredible job!!!
Thanks for re-post me discussion!
For sure now is the moment to fix the dashboard better that is possible.... i must look on ebay/amazon to find the right leds!
Many thanks!!
p.s: problems aside, I'm really having fun trying to fix the Paso a little at a time !!
Ducati Paso 750 '90
PostPosted: Tue May 05, 2020 8:52 pm
The p750 oil temp is the same as the p906 water temp gauge ....just has oil written on it . I bought a new Paso dash assy without thinking about the different gauges on the
P750 and P750 it but it works just fine
PostPosted: Wed May 06, 2020 7:33 am
Hey McTool,
OK so I "just" need to exchange the dial?
Have not looked into the matter but assume I have to carefully remove the plastic cover, then detach the pointer from the temperature gauge and then swap the dial? :?:
Or have you just left the water temperature dial on? :beer:
PostPosted: Wed May 06, 2020 9:16 am
Id just leave it as is , it does say oil but as for practicality its ok. Usually either sized paso heats up to a point and pretty much stays there. You will quickly learn where "normal" is .....which will be close to the middle of the scale. If you want to change the face over I havnt got one close by but I would see if you cant easily change it.....cant be that hard :lol:
PostPosted: Wed May 06, 2020 9:57 am
Mc Tool,
Thanks anyway, I have the new dashboard mounted on the front subframe but not connected sofar.
Always assumed that I had to change the whole temperature meter, but happy to hear that it is basically the same meter only with a different "dial". :rimshot:
I still have the original (old) dashboard and I intend to open and repair it ever once (perpex cover - replacement / home construction), but first I have to have my Paso ready (it will take a while since I am still waiting for my surgery and including rehabilitation I will be a year later :,( ).
Do you know if and where to get the original (electrical) pins for the dashboard? :?: :?:
I searched everywhere but I did not really succeed.
I am mainly concerned with the small brass galvanized particles since I am going to make a new (different from original) wiring harness myself (Motogadget). :wacko:
I can clean the white plastic connector and use them again, but I don't want to solder the old pins but to get new ones and crimp them on the new cables.
PostPosted: Wed May 06, 2020 1:36 pm
Marco, with regards to the shock, I had mine rebuilt by ORAM Sospensioni (http://www.oramsospensioni.it/)
actually i did something b"wicked" I got a Marzocchi monoshock from a Paso 750 that had the remote preloader for the spring and sent it to Oram asking them to make one to fit "temporarly" to my 907
it is so good that I never looked back and I left it on the bike despite being less sofisticated that the Marzocchi Duoshock I had on my 907.
Anyway, my suggestion is get either a monoshock or a duoshock on the cheap from ebay send it to ORAM and get it refurbished and it will last another 10 years.
PostPosted: Wed May 06, 2020 2:53 pm
Ducati Paso 750 '90
