ducatipaso.org • View topic - Hi from Italy!!
It is currently Mon Jun 15, 2026 11:05 pm
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Hi from Italy!!
PostPosted: Wed May 06, 2020 2:53 pm
Suzuki GSX-R 600 '00 (ex)
Ducati 999 '05 only track
Cagiva Elefant 750 '95 (ex)
Ducati Paso 750 '90
PostPosted: Thu May 07, 2020 7:50 am
This morning i wrote to ORAM SOSPENSIONI to have some more info about rear shock absorber.... i'm waiting some answer.
Anyway.....
i'm looking also to find this part:
but they are very rare and expensive!!! i've found on ebay (probably in England or Netherland) and they costs 22€ each one!!!! i need 4 pcs, so i must pay almost 100€ for 4 pieces of rubber!!!! :banghead: :banghead: :banghead:
this is how look now the electric panel.... i've change some wire and new connector....
Now i would like change also the oil pressure sensor and oil temperature bulb.... Moreover i have order a new horn, because the old owner install this two big trumpets with some kind of improvised connection!!!! :shock: :shock: :shock: :shock:
I've found new original horn at 9.99€!
Ducati Paso 750 '90
PostPosted: Thu May 07, 2020 9:49 am
PostPosted: Thu May 07, 2020 10:06 am
here they are cheaper: (the question always is about the actual stock)
https://www.motosparepartner.com/nl/oil ... 93135.html
PostPosted: Thu May 07, 2020 10:31 am
Hi Paso750, thanks for your answer....
About the plate i prepare it with primer and then black paint for high temperature.... i don't know how long the paint resist, but for the moment is the fast solution to improve the appearance of the electrical panel! for sure anodization is the best way to have a long/final solution.
All the connections with the grownd was cleaned to have a good contact, so from this point of view I am sure that the connections are efficient.
The idea to install the Showa removed from my 999 it's only because I have the shock absorber available at no cost .... moreover I have the possibility to build some type of adapter to install it (working for a company that builds industrial machinery, I have material and machinery available to build anything)..... i don't know, i will try.... if the final result or the necessary work does not satisfy me, I will buy a new shock absorber.
Finally, the dashboard....
after reading your topic about the led's installation, I'm going to do a job, I hope very good, like yours... :beer: :beer: :beer: :beer:
Ducati Paso 750 '90
PostPosted: Thu May 07, 2020 10:49 am
Ducati Paso 750 '90
PostPosted: Thu May 07, 2020 11:08 am
Ducati Paso 750 '90
PostPosted: Thu May 07, 2020 11:27 am
And sorry about my question, but someone in this forum ride his Paso on track!?
My idea when i will finish to restore my Paso is to ride it during days of free practice on the track for historic motorcycles... :mrgreen: :mrgreen: :mrgreen: :mrgreen:
like this man!!
:beer: :beer: :beer: :beer: :beer: :beer: :beer:
Ducati Paso 750 '90
PostPosted: Thu May 07, 2020 2:10 pm
Hey Marco,
I personally wouldn't anodise the electric base plate since the anodised layer is non conducting and since it used also as a mass ….
Have you asked "Rudi" from DUC-ONLY-Parts: rudyberends@kpnplanet.nl?
He is a well known used parts supplier for "older" Ducatis (and used on a regular base by several of this forum) and I would assume he has still some of these rubbers for little money.
Just in case the other suppliers can't supply, what sometimes happens, or for future parts.
PostPosted: Fri May 08, 2020 6:19 am
Ducati Paso 750 '90
PostPosted: Fri May 08, 2020 6:25 am
Regarding my beginning question about the installation of 999 Showa shock absorber i have bad news.....
As Paso750 and Frank.61 said, the wheelbase of Paso shock absorber is to long respect 999....
Paso: 367mm
999: 300mm
so i think it's no possible swap the units.... sin, I hoped..... :banghead:
Anyway..... next focus is buy the new shock....
I'm still waiting answer from ORAM, then i will decide if buy ORAM or Bitubo shock..... in Italy Bitubo is a very popular brand that make excelent product..... will see...
Ducati Paso 750 '90
PostPosted: Fri May 08, 2020 10:49 am
Marco,
Same engine, same helmet, year: 1985 ! :thumbup:
Have still the same Dainese leather suit (1983). :beer:
Quite a few famous people there: Kenny Roberts, Franco Farnè, Fabio Taglioni, Frederico Martini (if I see it correctly).
PostPosted: Fri May 08, 2020 12:33 pm
Ducati Paso 750 '90
PostPosted: Mon May 11, 2020 12:17 pm
Today i've received new horn....
Paid €9.99 on Motoshop.it, it looks well done.
This evening i'll install and test...
Ducati Paso 750 '90
PostPosted: Mon May 25, 2020 6:24 am
Hi folks!
Someone can show me the connector for oil temperature sensor mounted on oil Y connections between the two radiators?
Ducati Paso 750 '90
