ducatipaso.org • View topic - brake/clutch fluid resistant paint
It is currently Sun Apr 19, 2026 9:20 am
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2, 3  Next
 Post subject: brake/clutch fluid resistant paint
PostPosted: Sun May 17, 2020 2:08 am
anybody got experience with a suitable product for painting clutchcover, mines been damaged with a fuel spill but also clutch fluid, also rethinking drilling and venting while the engines out
 Post subject: Re: brake/clutch fluid resistant paint
PostPosted: Sun May 17, 2020 10:23 am
I've had good results on engine casings using this stuff but along with their etching primer.
I don't know if you can get it in Oz.
PostPosted: Sun May 17, 2020 12:01 pm
thanks Derek i,ll check that out, probs cant get it here
PostPosted: Sun May 17, 2020 1:32 pm
One would imagine brake caliper paint is resistant against brake fluid.
It's mentioned here: https://www.nonpaints.com/en/vht-calipe ... in-aerosol
I'm guessing you can find VHT paint in Australia.
It's best to heat up the part first or bake the paint in later.
I've always used black (epoxy) garage floor paint (here referred to as liquid plastic) for axle and suspension parts of my cars. That stuff is resistant against almost everything and holds up really well. It's thick though and can't be sprayed so nothing for your clutch cover.
PostPosted: Sun May 17, 2020 2:50 pm
A 2K paint should do the trick (the most chemical resistant paints).
In Australia you could use Eastwood 2K Aero Spray HT Engine Paint Gloss Black.
http://www.ppcco.com.au/eastwood1.html
But be a little careful with brake fluid (that's really aggressive stuf).
If you spil it flush it immediately with water to prevent it from damaging the paint.
Good luck!
PostPosted: Sun May 17, 2020 4:24 pm
for $132 for a can of primer and paint you can almost get a spare clutch cover.
Another option would be to clean out the complete clutch system thoroughly and go for DOT5.
PostPosted: Sun May 17, 2020 7:51 pm
Gerhard, Australian dollars are not US dollars....
Also: it's an example: just more or less any 2K paint will do the trick (clutch cover will become maybe 125 celcius/260 fahrenheit max. I assume and all 2K can take that).
Eastwood is just a well known brand in the USA for cars & motorcyle restauration projects.
I have used VHT since years (40 or so) but lately I discovered that they are not really fuel resistant (although they say it should - and in the past it did!).
So for me. either powder coat or 2K if you want fuel- and a little brake fluid resistance …
PostPosted: Mon May 18, 2020 7:19 am
PostPosted: Wed May 20, 2020 11:57 am
I'm liking al the ideas , thanks all, I think the caliper paint makes a sense I'm going for that
PostPosted: Thu May 21, 2020 9:19 am
another option to fix the problem for good would be polishing the cover.
PostPosted: Fri May 22, 2020 2:56 am
Now there's a thought, that's something I can do, have you seen this done on one of these, I might give it a crack, nothing to lose really if it looks wrong just paint it
PostPosted: Fri May 22, 2020 6:30 am
I had two polished ones but to be honest I prefer them in black ;)
PostPosted: Fri May 22, 2020 8:11 am
Nice, do you think the drilling is the way to go
PostPosted: Fri May 22, 2020 11:11 am
Here I've a little relief in the paint (difficult to see on this low res. pics), looks nice in reality.
Is powdercoat by the way.
PostPosted: Fri May 22, 2020 5:51 pm
