ducatipaso.org • View topic - 907 ie chain adjuster wanted
It is currently Sat Feb 28, 2026 9:54 am
 Post subject: 907 ie chain adjuster wanted
PostPosted: Sun May 17, 2020 5:35 pm
Does anybody have a chain adjuster I can buy? I went out on my bike today and it has sheared the bolt and lost the gold plate of the adjuster!
The Benelliman
1992 907ie
1981 Benelli 900 Sei
1989 Benelli 900 Sei
1976 Benelli 125 Enduro
1981 Benelli 250 2c
1976 Benelli 250 Quattro
 Post subject: Re: 907 ie chain adjuster wanted
PostPosted: Tue May 19, 2020 7:38 am
I don't have one but are you looking for left or right side?
The end plates are the same for the SS/851/888/ and Monster. The bolt is used in the same models plus Multistrada and ST2/3/4.
PostPosted: Tue May 19, 2020 10:34 am
Still available from Stein Dinse
PostPosted: Wed May 20, 2020 10:26 am
I wonder why the bolt broke in the first place. I'm guessing it was tightened a bit more after the axle nuts were or the axle came loose (or the conical spacer is installed the wrong way around?!). The bolts are M8x90mm btw.
Since I had read about this also in other forums I lockwired mine. Lockwiring the bolt may have been overdoing it considering the chain has to be checked and readjusted once in a while.
PostPosted: Wed May 20, 2020 8:21 pm
I think the bolt had Metal fatigue and snapped when I accelerated.
Thanks Derek I have ordered the part from Stein Diense!
It was my first ride in 6 months bike is running well glad I spotted the missing adjuster before the wheel could move!
The Benelliman
1992 907ie
1981 Benelli 250 2c
PostPosted: Sun May 24, 2020 6:22 pm
also a solution. :truck: Found on the ducati.ms forum.
