ducatipaso.org • View topic - selling some bits for the 906 & 907IE
It is currently Wed Apr 15, 2026 1:03 pm
 Post subject: selling some bits for the 906 & 907IE
PostPosted: Sun May 24, 2020 5:35 pm
I'm letting some parts go I don't need.
- DUCABIKE Air-System clutch pressure plate, new - said to be able to cool the clutch by up to 10°C - fits about all 900cc Ducatis with dry clutch (with clutch slave piston on the left engine side) incl. a set of new black spring plates. €70
- 907IE flywheel, used. The idea was to lighten it, but that never happened. Any offers?
Prices are open for discussion - in a reasonable range :)
Worldwide shipping is no problem.
 Post subject: Re: selling some bits for the 906 & 907IE
PostPosted: Mon May 25, 2020 7:50 am
Gerhard,
Is the Wilbers strickly 906?
I always assumed 750/906 were identical (at least size wise).
PostPosted: Mon May 25, 2020 8:43 am
Let's put it like this. Its german TUV/approval documents only cover the 906 so here in Germany you can only use it for that. It is possible that the P750 isn't listed simply because they didn't have one to test it with. I don't know. The dry weight of the P750 is 195kg, the 906s is 205kg so maybe the spring Wilbers used in it might be a little stiffer than one they would use for a P750 shock. (They don't offer a P750 shock).
Other manufacturers like Bitubo make one shock that fits both P750 and 906 and size-wise, due to the same frame dimensions and the identical swingarm, they are identical.
It might be a german thing. Many parts for brakes, suspension etc require approval documents which means manufacturers have to get single approval for every vehicle they want to sell the parts for which is costly. If a vehicle isn't listed in those documents (it may the the same model of vehicle but with a different motorisation) you can't legally use that part on it which does not mean you can't visit the TUV yourself and try to get it approved this way. Of course you'll have to pay for that inspection and approval and it isn't said that the TUV inspector will actually approve it. The german burocracy regarding all this is rather strange and sometimes a bit confusing. For instance there are different type of approval documents like the ones you just have to carry with you to prove the legality, others require inspection by the TUV and documenting in your vehicle papers. Then there are material reports ... you get the picture ;)
The Wilbers next to a P750 Marzocchi. They are both 365mm long. Mounting point width and size are all identical.
PostPosted: Mon May 25, 2020 11:41 am
Dibs on the axle plates.
You got pm.
