ducatipaso.org • View topic - 750S Brought back to Life
It is currently Sun Jun 21, 2026 8:11 am
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: 750S Brought back to Life
PostPosted: Fri May 15, 2020 6:13 pm
PostPosted: Fri May 15, 2020 6:15 pm
I have also thought of putting on FCR39's but the TM-36 run fine and I'm enjoying the bike too much to dismantle everything just for the FCRs. I also was fighting to get the clutch piston and pressure plate to line up properly, and believed to have resolved the issue. Can't go without a little drama on this old thing :)
PostPosted: Sat May 16, 2020 9:26 am
model: other
year: 1999
Thanks heaps for the base line data. Really appreciate it. Glad they run well.
2013 M1100Evo Street
1999 M750 "Scrambler"
2004 GSXR750 Track
PostPosted: Mon May 18, 2020 6:50 am
You're welcome! Hopefully they work out well for your case, too!
PostPosted: Sat Jun 06, 2020 9:35 pm
model: other
year: 1999
I got hold of two used slant bodied horizontal FCR39's with choke (enrichment) knobs designed for dirt bikes. Powerbarn provided a 2 into 1 throttle kit and Niche Cycle supplied manifold boots. After some fiddling they work well (on an M750 modified to dual sport). MikuniOz can sell everything to build a TM kit similar to your set up and I would recommend that as an easier cost effective kit for belt drives. Used FCRs can cost more than a complete kit for the TM 36/38. I'll do the TMs as a budget option if not requiring an accelerator pump. Thanks again for sharing.
2004 GSXR750 Track
PostPosted: Sun Jun 07, 2020 8:00 am
PostPosted: Sun Jun 07, 2020 8:06 am
Roger,
Perfectly executed, kind of restomod. :thumbup:
Love the black air cooled desmodue engines (with the alloy belt covers).
What did you do with the exhaust manifolds/pipes, is that paint or ceramic coating?
Have lots of fun with it! :beer:
PostPosted: Fri Jun 12, 2020 5:27 pm
Thanks, Frank! I inherited the bike pretty much how it looked :) I just brought the internals back to life and up to date. The header and pipes were painted, I think. My contributions were mainly the carburetor tuning, ignition coils, fuel filter, and chain/sprockets.
I also have a new shock on the way to bring up the rear end to quicken steering and reduce the shallow lean angle :D
Thank you!
-Roger
PostPosted: Fri Jun 19, 2020 2:36 am
model: other
year: 1999
:thumbup:
2004 GSXR750 Track
PostPosted: Thu Jun 25, 2020 4:56 pm
New shock installed. The bike now handles like a real motorcycle :D
Pictures here: https://photos.app.goo.gl/mjzezkNW6pnVsgRy6
PostPosted: Thu Jun 25, 2020 9:36 pm
The shock looks great. What type is it? Also what length did you go for? Is this standard. Inquiring minds need to know (well I need to know for future options on mine!
Yours selfishly
Keith MM in a super hot London
PostPosted: Fri Jun 26, 2020 4:40 pm
Keith,
The shock is from Cogent Dynamics Engineering. It is 13.375 in (340 mm) long at the shortest and can be adjusted out quite a ways. The original carb SS shock was 13 in (330 mm), which had the bike steering quite slow in comparison. The SSie shock at 13.25 in (336 mm), offered a good length for many carb SS riders for quicker steering. Hopefully this helps!
-Roger
PostPosted: Sun Jun 28, 2020 7:02 pm
Thanks Roger, that’s very informative. Hopefully I will start getting my 750 sport sorted this year!
Best regards
Keith MM
PostPosted: Wed Jul 01, 2020 7:09 pm
You're welcome, Keith! Happy to help and best of luck on getting your 750 running well :)
PostPosted: Wed Jul 22, 2020 3:50 am
model: other
year: 1999
Put these on.
by , on Flickr
2004 GSXR750 Track
