It is currently Tue Oct 27, 2026 3:28 pm
 Post subject: Fuse Block
PostPosted: Mon Sep 07, 2020 1:15 pm
Anyone ever replace the fuse block on a 907? Mine is falling apart. Literally crumbling. Whatever the material is, it was not made to withstand the test of time.
Does anyone have a good aftermarket replacement for that item? I did order one for marine application, but it is a little large. It may work, and is high quality, but I think I will look for one closer to the original size.
1992 907ie, (x2) Anthracite
 Post subject: Re: Fuse Block
PostPosted: Mon Sep 07, 2020 3:02 pm
Eastern beaver has some good ones
PostPosted: Mon Sep 14, 2020 5:26 am
When mine fell apart I used a Narva 54420BL. I used insulated spade connectors and bent the terminals a bit for clearance.
Willo
Wannon Victoria Australia
Willo
91 907ie
95 748
