It is currently Wed Oct 28, 2026 9:44 am
[ 2 posts ] |
| Author |
yosemite
Post subject: fuel gauge bounces Posted: Thu Jan 21, 2021 12:13 pm |
Joined: Sat Apr 28, 2018 9:31 pm Posts: 8 Location: Ireland
Hi was out on the 906 yesterday for a test ride and to get fuel, the only problem is the fuel gauge was fine when filled but after a while when fuel level started to drop the gauge started to bounce up and down quite rapidly. when I got back with the bike on its stand the gauge was steady but if I rocked it then the needle would bounce Is this normal or is there meant to be some sort of damping on the gauge. I was thinking of connecting a capacitor accross the gauge to smooth out the reading. Does any one have any thoughts?
| Top |
Duc906
Post subject: Re: fuel gauge bounces Posted: Fri Jan 22, 2021 3:32 am |
Joined: Mon Mar 30, 2009 7:59 pm Posts: 269 Location: Australia
I had the same issue with mine, when the fuel level got down to near half the needle on the gauge would bounce or drop to empty. The issue I found was with the fuel level sender it the tank. The wiper arm in the sender unit wasn't making contact with the coil in the middle. I just bent the wiper arm so that it made contact all the way across the coil and it fixed the problem. I wish I had taken some photos when I had it apart but I found this video that goes through a similar issue.
| Top |
[ 2 posts ] |
Users browsing this forum: No registered users and 1 guest |
