ducatipaso.org • View topic - Racing chip?
It is currently Sat May 02, 2026 2:32 pm
 Post subject: Racing chip?
PostPosted: Mon Mar 20, 2006 2:30 pm
Hi everybody,
I have bought on eBay from a canadian seller a couple of stock mufflers.
The seller has shipped to me also a chip (n. 91270201A) that increases the performances of 907 ie USA.
On the attached paper I can read that: "With these modifications you'll change the data submitted for the motorcycle type approval; therefore use the modified motorcycle only within closed tracks".
On the chip it's a label: "DUCATI 907ie -023U-".
Could I use it on my european 907? How does much would be the performances increase?
Ciao.
PostPosted: Mon Mar 20, 2006 3:16 pm
That is NORMAL USA chip for 907IE, and that chip is designed to tune engine MORE LEAN, than normal 907 Chip, what is marked -023- That "U" means, that its USA chip. Its safe to use that with EURO bike and with normal mufflers, but it is NOT so good, as EURO chip)-023- ; what is more rich mapped. Dont use ever that USA chip with open muflers, or then You have maybe big problems with burned exhaust valves! You are warned now! :thumbup:
PostPosted: Mon Mar 20, 2006 4:01 pm
Therefore, this chip wouldn't give more performances. Only more troubles :thumbdown: !!
Thanks Antti
PostPosted: Mon Mar 20, 2006 8:00 pm
Yes, not anymore horsepower, cause more lean fuel ratio, than in normal EURO chip -023-. Near allways USA Ducatis have been fitted with leaner chips, cause there are tighter emission rules = leaner fuel ratio. So, NO "RACING chip", i am sorry, Francesco! :sad:
PostPosted: Thu Mar 23, 2006 3:31 am
when i purchased 907 the owner gave me what he said was stock u.s. chip(ducati 907ie 023u) checked chip presently in bike with k&n filter, open staintunes the chip is fim 907bp692, any one can confirm this chip 907bp692 is the right set up for mods...no other mech. mods/stock motor
PostPosted: Fri Mar 24, 2006 7:36 am
The seller probably have sold her OEM parts after he tuned the bike
