It is currently Wed Oct 28, 2026 7:38 pm
[ 5 posts ] |
| Author |
Bzapcat
Post subject: Fan thermo sensor/switch Posted: Tue May 04, 2021 12:21 am |
Joined: Wed Feb 13, 2019 2:05 pm Posts: 19 Location: Doylestown PA
Apparently my fan thermo switch is bad. Does anyone know of a replacement for the sensor/switch ? I've read that it's a common sensor/switch. But I am having a hard time finding one that is a correct fit. Of course I can always run a bypass switch but I'd rather use a workable thermo switch. Thank you!
| Top |
Derek
Post subject: Re: Fan thermo sensor/switch Posted: Tue May 04, 2021 9:09 am |
| paso grand pooh-bah |
That thermo switch was used on the 906, 907ie, 851, 888 and 9176 and early 748 but is no longer available.
However the switch for the later 748 and the 996 is available. It is essentially the same switch but with a different connector. It would need the connector of the 907 loom changed to fit.
| Top |
du907
Post subject: Re: Fan thermo sensor/switch Posted: Thu May 06, 2021 4:48 pm |
Joined: Fri Jul 08, 2005 12:00 am Posts: 336 Location: Winston-Salem, N.C. USA
A lot of this type of part was also common on cars. Isn't there a site or posting of common parts that where also used on cars at the time? Maybe it's on that list.
| Top |
Bzapcat
Post subject: Re: Fan thermo sensor/switch Posted: Sun May 16, 2021 2:27 am |
Thank you Derek! I did a search for the 916 temp switch and found an aftermarket switch a lot cheaper. I also picked up a "lower" temp switch and installed that one first. It has the same electrical terminals as the 907. Thought I'd give that a try first before cutting and splicing a electrical plug for the newer style.
| Top |
Finnpaso
Post subject: Re: Fan thermo sensor/switch Posted: Fri Sep 03, 2021 11:05 am |
Joined: Mon Jul 26, 2004 12:00 am Posts: 3081 Location: Finland
Can You put some link here about that 916 switch. I mean, that where You bought it and what was price?
_________________ Antti http://www.youtube.com/watch?v=HeKOh3XoXPg&NR=1 KTM 990 Adventure -08 metal dark grey Paso 750 -89 red/metal grey Paso 907IE -91 red/metal grey Paso 907IE -91 red 2xST4S -02 red/metal grey ST2 -01 red/metal grey Volvo V70 Bi-Fuel Classic/titanium
| Top |
[ 5 posts ] |
Users browsing this forum: No registered users and 10 guests |
