It is currently Sat Jun 13, 2026 7:03 am
| Author |
Mike's bikes
Post subject: US Spec P750 Weber Recalibration Posted: Tue May 04, 2021 6:08 pm |
Joined: Tue May 04, 2021 1:25 pm Posts: 10 Location: USA
I know that this is a well worn subject, but I have not seen a report of successfully recalibrating the originally equipped Weber carburetor on a US spec P750 model. I have gotten mine to run very well using only currently available Weber jets and parts, with no soldering or drilling of emulsion tube holes. I thought this might be useful information or at least another data point for others.
Mine is a standard 1988 US specification P750 with the originally equipped mufflers, airbox and air filter element. Here are the changes from the original calibration:
main jet changed from 145 to 150 idle jet changed from 55 to 60. (edit:. Changed to size 57 due to hot weather richness) auxiliary venturi changed from 3.5 to 4.5 (Weber part number 71102.450 w/tube height identical to original, not the extra tall version) plastic float set to 43mm height fuel pressure set to 2.5psi All other jets and settings are per original US spec.
Before making the changes, I suffered the same complaints as most other Paso owners; hesitation and flat power on acceleration at 2500 RPM and while cruising from 4000 to 6500 RPM. Now, once warmed up, the bike runs as well as any carbureted motorcycle I have had. Gerhard has reminded me that the US spec P750s have more restrictive mufflers than Euro models and that the US P750 carburetor has a 34mm venturi vs. 36mm for the Euro model. Therefore, my calibration may be useful only for US spec P750s.
| Top |
Mike's bikes
Post subject: Re: US Spec P750 Weber Recalibration Posted: Wed May 05, 2021 2:58 pm |
Thank you, Gerhard, , I thought the differences between US and Euro spec carbs were the jet and venturi sizes. My venturi definitely measures 34mm ID, though I don't remember what number is stamped into the carb body. The unreliable nature of printed specifications is why I refer to such information as merely "data points".
| Top |
Frank.61
Post subject: Re: US Spec P750 Weber Recalibration Posted: Fri May 07, 2021 3:35 pm |
Joined: Fri Jul 24, 2015 11:21 am Posts: 261 Location: Belgium
Hi Mike,
1 question: which emulsion tubes does yours have?
_________________ Bimota SB4-S - 1984 Ducati Paso 750 - 1989 Suzuki SV1000S - 2008 Ducati Monster 796 abs - 2010
| Top |
murphus
Post subject: Re: US Spec P750 Weber Recalibration Posted: Fri May 07, 2021 6:23 pm |
Joined: Wed Jun 24, 2020 6:27 pm Posts: 50 Location: USA
Thanks for posting the info. I read Romus and Higgy's writeup and using the tall 4.5 venturi, interesting that you've apparently had good success using the "standard" 4.5, which is readily available, whereas the tall 4.5 is not, at least near as I can find. I'd really like to see if I can get my '88 Paso working on the original Weber. It's set up with 38mm Mikuni TM-style flat slides right now, and while they seem to be OK, I'd like to return the bike to stock. From everything I'm reading, it appears more than possible to get the Weber to work properly.
_________________ 1973 BMW R75/5 1974 Laverda SF2 1976 Suzuki GT185 1983 Lavarda RGS 1000 1988 Ducati Paso 750 1995 BMW K75
| Top |
Mike's bikes
Post subject: Re: US Spec P750 Weber Recalibration Posted: Fri May 07, 2021 7:19 pm |
| Top |
Mike's bikes
Post subject: Re: US Spec P750 Weber Recalibration Posted: Fri May 07, 2021 7:37 pm |
| Top |
murphus
Post subject: Re: US Spec P750 Weber Recalibration Posted: Mon May 10, 2021 3:00 pm |
Did you have any trouble removing the auxiliary venturi? The Weber manual says to carefully file away any staking marks before removal, but I don't quite see how that's done as they're small and hard to reach. It seems a heat gun might help?
| Top |
Mike's bikes
Post subject: Re: US Spec P750 Weber Recalibration Posted: Mon May 10, 2021 5:10 pm |
I used a 3-corner scraper and then an exacto knife to remove the staked material. The auxiliary venturi came out fairly easily using a small aluminium drift against the support arms, working side to side.
| Top |
murphus
Post subject: Re: US Spec P750 Weber Recalibration Posted: Mon May 10, 2021 10:32 pm |
Thanks for the tip. Stripping the Weber down shows - no surprise - that someone's been in it before. A small section is broken out of one of the auxiliary venturis at the top. Further, one of the emulsion tubes is broken at the top where the air jet fits over it, and both main jets show marks from, I assume, being pulled from the emulsion tubes. Which brings me to another question: The Weber manual says to "reform" the main jet seating at the bottom of the emulsion tube using the special Weber tool. I'm not clear what's being done, and is it necessary when installing new emulsion tubes and jets?
| Top |
Mike's bikes
Post subject: Re: US Spec P750 Weber Recalibration Posted: Mon May 10, 2021 11:07 pm |
I do not know what the Weber manual means by "reform". I had no trouble separating the main jet from the emulsion tube ... it just pulled off and the emulsion tube was undamaged. I didn't need anything but a couple of pair of pliers to lightly grab the e-tube and jet. My bike has low mileage, I could guess that less well preserved bikes have corrosion locking the jet to the emulsion tube.
If the parts don't separate easily, you might want to soak the e-tube and jet assembly in penetrating oil.
| Top |
Mike's bikes
Post subject: Re: US Spec P750 Weber Recalibration Posted: Tue May 11, 2021 12:51 pm |
| Top |
murphus
Post subject: Re: US Spec P750 Weber Recalibration Posted: Tue May 11, 2021 6:07 pm |
I think you're exactly correct. It sounds as if there was/is a forming tool matching the cone shape of the jet used to assure proper seating. Interesting. I wonder how one confirms proper seating without it? Maybe a little Prussian blue dye and push the tube with jet into place and see if there's full contact? Anyway, thanks. I'm getting more and more intrigued by the idea of getting the Weber into operational shape and seeing if I can get the Paso to run well with it. The previous owner couldn't, but looking at the condition of things it's almost no wonder. And I don't think the original Weber has more than a few thousand miles on it.
| Top |
Mike's bikes
Post subject: Re: US Spec P750 Weber Recalibration Posted: Wed May 12, 2021 2:07 am |
murphus, have you measured your main venturi ID? Whether it is 34 or 36mm may make a difference in the jetting.
| Top |
murphus
Post subject: Re: US Spec P750 Weber Recalibration Posted: Thu May 13, 2021 8:13 pm |
Haven't yet as I've yet to remove the auxiliary venturis, but will report back when I do. Will be curious to see what size it actually is.
| Top |
Users browsing this forum: No registered users and 100 guests |
