It is currently Wed Jun 10, 2026 1:18 pm
[ 3 posts ] |
| Author |
Crumpati
Post subject: Clutch slave rubber boot?? Posted: Thu May 13, 2021 6:58 am |
Joined: Mon Nov 28, 2011 8:50 am Posts: 30 Location: idsvold QLD Australia
Hi again guys, on my voyage of discovery I unbolted the clutch slave to see if it was leaking, (Id lost clutch about 5 years ago and had to refill and bleed it up). It appears there was no leak of fluid, but it must have gone somewhere? Is this normal for it to disappear over the years.The other thing was the rubber boot which I presume protects the actuator rod from the chain gunge has a hole in it, so I will need to replace. Does the small end of the boot go on the rod and the big end to the piston or the other way round? Is it just held in place by the sprocket cover? thanks again.
| Top |
Derek
Post subject: Re: Clutch slave rubber boot?? Posted: Thu May 13, 2021 9:14 am |
| paso grand pooh-bah |
Big end goes against the piston. It is simply sandwiched between the slave cylinder and the end of the shaft.
| Top |
Crumpati
Post subject: Re: Clutch slave rubber boot?? Posted: Fri May 14, 2021 6:06 am |
thanks for that. After pulling the piston and tidying up the bore I have decided to replace the piston, seal and spring. Apparently I should replace the push rod O rings as well. The pushrod pulls out without too much resistance so the O rings will be a simple job, there are no oil leaks at the moment from either end. Should I replace any other seals now I have disturbed the push rod?
| Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 18 guests |
