It is currently Mon Oct 26, 2026 6:14 am
 Post subject: Paso Fairing Fittings - Well Nuts
PostPosted: Sat Oct 09, 2021 5:59 pm
Does anybody know where I can get the correct well nuts to secure the side panels to the gas tank on my '88 Paso? They're smaller than currently available "standard" 6mm well nuts, which seem to come in at around 12.5 to 12.7mm; the fixing holes in the gas tank are approx. 10.5 to 11mm.
1973 BMW R75/5
1974 Laverda SF2
1976 Suzuki GT185
1983 Lavarda RGS 1000
1988 Ducati Paso 750
1995 BMW K75
 Post subject: Re: Paso Fairing Fittings - Well Nuts
PostPosted: Sun Oct 10, 2021 7:17 am
:phone: I have in the past found them at HomeDepot,MSC Direct or McMaster Carr.
Any larger industrial supply company should have a wide range available
PostPosted: Mon Oct 11, 2021 12:16 am
I can find 6mm well nuts no problem, but they're all made for a larger hole size and won't fit fixing points on the gas tank. At least the one I got will not compress enough to fit. It appears it needs to fit an 11mm hole, not a 12.5 as most of what I'm finding is specified for.
1973 BMW R75/5
1974 Laverda SF2
1976 Suzuki GT185
1995 BMW K75
PostPosted: Mon Oct 11, 2021 7:19 am
try MSC or McMasterCarr or
fix the holes :smoke:
PostPosted: Wed Oct 13, 2021 12:56 pm
i use the same plugs on all fittings on my 906 but also on the 750 i had. So fix the holes like Higgy wrote.
Kawasaki Z700 1987, Kawasaki ZL1000 1990, Ducati PASO 750 1990,
Ducati 900ss 1993, Ducati Paso 906 1990
PostPosted: Tue Oct 19, 2021 7:58 pm
I found some 12mm well nuts at an outfit in Ohio. A little grease and they fit nicely.
https://zspecdesign.com/m6-rubber-compo ... -10-packs/
1973 BMW R75/5
1974 Laverda SF2
1976 Suzuki GT185
1995 BMW K75
