It is currently Wed Feb 25, 2026 1:48 pm
Post new topic Reply to topic  [ 470 posts ]  Go to page Previous  1 ... 28, 29, 30, 31, 32
PostPosted: Tue Oct 12, 2021 10:33 am
They are pretty rough guestimate, another look tells me pistons more like 25 mm and maybe 26.5 mm on bore
PostPosted: Tue Oct 12, 2021 11:51 am
I'll measure mine tomorrow and get back to you. The seal is 26mm outside diameter so your bore would probably be less than that I would say.
PostPosted: Wed Oct 13, 2021 10:14 am
Here's the measurements but for some reason the piston diameter kept coming out higher than the bore diameter haha. I couldn't get the verniers far enough into the bore. The piston is a nice snug fit with a small amount of movement.
PostPosted: Wed Oct 13, 2021 9:27 pm
Andrew it looks as though we both won't have any worries there, go fo it mate , especially with the v seal you'll be sweet. Looking forward to seeing your progress going forward.
PostPosted: Wed Oct 13, 2021 10:51 pm
Cheers. I'll have a crack at it in the next couple of days. Once that's done it's ready to ride so fingers crossed it'll work.
