ducatipaso.org • View topic - Clutch resevoir rebuild kit
It is currently Mon Sep 29, 2025 10:11 am
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: Clutch resevoir rebuild kit
PostPosted: Fri Mar 31, 2006 3:52 pm
Does anyone know if Brembo makes a rebuild kit for the clutch/brake resevoirs?
I've got traces of fluid showing on the outside of the rubber where the cltuch lever pushes in at the bottom of the perch/resevoir unit. If it's a standard Brembo part, or only an OEM Ducati part.
Thanks in advance!
Jim
PostPosted: Fri Mar 31, 2006 7:04 pm
Remembering.... that clutch and brake are different and another can be found from Ducati dealer, but cant remember, whitch one... Shit! , i am getting too old to remeber all... :sad: i think, i can find that from my 1000 notes from garrage, if You really need that info... but maybe tomorrow... :thumbup:
 Post subject: Re: Clutch resevoir rebuild kit
PostPosted: Sat Apr 01, 2006 3:40 am
-Craig
PostPosted: Sat Apr 01, 2006 12:57 pm
PostPosted: Sat Apr 01, 2006 1:46 pm
-Craig
PostPosted: Sat Apr 01, 2006 8:10 pm
PostPosted: Mon Apr 03, 2006 2:16 am
Thanks to all for the detailed information. I'm going to do some checking on the Guzzi sites, since I also understand they share alot of parts.
Best regards,
Jim
PostPosted: Tue Apr 04, 2006 5:12 pm
PostPosted: Wed Apr 05, 2006 10:01 pm
PostPosted: Thu Apr 06, 2006 7:44 am
Hi!
Its very good, that here are also Italians, (no matter are they gigolos, or no) so, they can confirm many things about Italian language translations and Italia styles "to understand Ducatis" better :thumbup:
To pump: I think, it very good idea to go for better pump, when update front brakes, like You do. There are some ways to do it and those radial pumps are very good equipments, if looking batter "feel" to front brakes, what are MOST important brakes in motorbike! ESPECIALLY, if such radial pumps can be found from Italy(where that are mostly made) for good price. I think, thye are most cheapest there, not anywhere else :confused: Can You say some prices about radial pumps, those Discacciati and Brembo units there in Italy??? I am thinking revision to ST4S to put such there and then add ST4S pump to my 907 and that 907 original to spare unit, for both 907 and my 750 Paso, where i put already 4 piston Brembo system with BIGGER PS 16 pump, than that original PS 13, what 750 and 906 Paso have. If 4 piston system, then that older PS 13 DONT have enough capacity to function! Maybe we can make some deal to buy those radial pumps more/cheaper and everybody will be happy then? I write just yesterday something, like this about DZUS fasteners, cause they are best and not cheap here in Finland... Near allways things seems to be cheapest in they manufacturing countries.... Like spirits also! There are "wine" countries", where "own wines" are quite cheap and beer countries, like Czec republic, where very good beer is very cheap. :thumbup: :thumbup: :thumbup:
Anyway that Your update can be very vise, cause those new pumps are much better quality and that "feel", when braking. Thats Why i am also intrested such to my ST4S.
Can You check prices of those pumps, Fransesco in Italy markets? :thumbup:
PostPosted: Thu Apr 06, 2006 4:45 pm
PostPosted: Thu Apr 06, 2006 4:56 pm
 Post subject: Re clutch/brake replacement kits
PostPosted: Fri Apr 07, 2006 9:56 am
PostPosted: Fri Apr 07, 2006 2:07 pm
PostPosted: Fri Apr 07, 2006 6:43 pm
