ducatipaso.org • View topic - How do I remove the wirenet oil filter ???
It is currently Sun Mar 01, 2026 8:27 pm
 Post subject: How do I remove the wirenet oil filter ???
PostPosted: Thu Apr 06, 2006 4:15 pm
PostPosted: Thu Apr 06, 2006 4:40 pm
 Post subject: I thought that was what I would have to do.
PostPosted: Thu Apr 06, 2006 5:34 pm
 Post subject: Success !!!
PostPosted: Thu Apr 06, 2006 6:26 pm
PostPosted: Thu Apr 06, 2006 7:04 pm
PostPosted: Thu Apr 06, 2006 7:26 pm
PostPosted: Fri Apr 07, 2006 9:19 am
PostPosted: Wed Jun 07, 2006 12:24 pm
Hi boys, just wanted to say THANX to all concerned in this discussion.
Just browsing through the messages this morning, I read about the wireframe filter problems of our new friend here, and stepped on Antie's (finpaso) remark about metal particles on the filter.
I have just changed the oil yesterday and checked the filter. It was full of shiny metallic Ducati Character.!!! I bacame so desperate, though this was the end of my engine. And today I read your mails.
What a relief, there must be God after all.!!
Thanks.
Friendly regards
Peter - PASO750
PostPosted: Wed Jun 07, 2006 6:50 pm
:thumbup: most of that metal come from gearbox.... hondas dont have "character", so If You are too worried about that shit, buy honda and try to be happy with it... :funny:
PostPosted: Sat Jun 10, 2006 4:35 am
Just a small thought: my 900ss has character, and that character is defined by the characteristic of a large steel oil galley plug backing out of the side of the crankshaft, and slowly eating away the aluminum case.
If you've got steel in your drainpan, it's probably a bearing, maybe transmission swarf. Aluminum shavings looking like fingernail clippings spell big trouble. This was a very common problem on 91-92 900's, not sure if Pasos ever had this problem.
PostPosted: Sun Jun 11, 2006 8:20 pm
PostPosted: Wed Jun 14, 2006 8:20 am
 Post subject: How do I remove the wire net oil filter ???
PostPosted: Tue Aug 22, 2006 4:05 am
Marinus,
Should I jack up the engine while the bike is on the center stand? Seems like that might unload it, causing the spring to pull it up.
Perhaps you use one or both of those front/rear axle stands?
Make it a good day,
Sheldon
'88 Paso
'62 200 GT
'78 Laverda 3CL Jarama
'84 Laverda RGS 1000
PostPosted: Tue Aug 22, 2006 5:02 am
:cool:
Don't worry, you don't usually need to move things much to get bolts to slide through.
