ducatipaso.org • View topic - Aftermarket Exhaust - 750 vs. 907
It is currently Thu Jun 18, 2026 9:06 am
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
PostPosted: Wed Apr 26, 2006 3:08 pm
PostPosted: Thu Apr 27, 2006 11:32 am
PostPosted: Thu Apr 27, 2006 11:33 am
PostPosted: Thu Apr 27, 2006 2:51 pm
[quote="Duc750"]Also
Hi Duc750,
What a brilliant idear :thumbup:
A simple solution - i will give it a try.
Thank you so much
Kind regards,
Jacob
PostPosted: Sat Apr 29, 2006 6:34 pm
Jacob, I am very sorry, that i cant sell any pair, cause soon i try put both my Pasos to my "museum" and i have two kids(11 & 14)and i let Pasos to them, WHEN they know exactly, what they are sharing, not before and i think i want to help also them then with they Pasos and surely they also want to change pipes and test, etc... allkind mufflers in they Pasos, so pitty, that i cant sell any pair now... :sad:
To "noise killers, etc"... : I think every country have local rules about mc noises, so better first look them. I have earlier writed, how it function in Finland in some topic. Anyway, if country have somekind "early check"(what not yet in Finland :funny: ) Its very simple to buy/put metal "net" inside to mufflers, when its time to take bike to "year check", after easy to take them away and again You can enjoy nice/loud Ducati sound, BEST EVER sound in mc world!!! :thumbup:
PostPosted: Sat Apr 29, 2006 8:41 pm
Hi Finnpaso,
Finn wrote:
Its very simple to buy/put metal "net" inside to mufflers, when its time to take bike to "year check", after easy to take them away and again You can enjoy nice/loud Ducati sound, BEST EVER sound in mc world!!! :thumbup:[/quote]
No probs - It was just a try :evil:
I will buy a db killer or even make a light version from steel wool and metal net. But thanks for your respons :thumbup:
KR Jacob
PostPosted: Fri May 05, 2006 1:13 am
Finnpaso,
If you have the smaller exhaust pipe size, at the point that the slip ons mount to the pipe, would it be possible to use a 2 mm (36mm to 40mm) shim or collar to make up the difference in tube size? For $500 to $750 that the Two Brothers cost I hope they are lighter, increse horsepower and are better sounding than anything else!
Doug
PostPosted: Fri May 05, 2006 1:30 pm
Mine are bigger ones (40mm) and its only good way to change headers to better flow 40mm ones and then connect pipes directly to those, without any shim or coller. And You cant make more hp, if only change better flow pipes. NEED also better INTAKE AND SURELY MORE FUEL(richer mixture!!) to get more POWER! :evil: If change only to free flow pipes and not change fuel mixture, then Your exhaust valves can burn, what is not so nice to look :sad: I have seen some such Ducati cases :thumbup:
NEVER more hps WITHOUT MORE FUEL!!!!
PostPosted: Sat May 06, 2006 1:21 am
Finn,
Are all 750 exhaust ports large enough for the 40mm headers or do the US models have to stay with the 36mm? Can you change any Paso 750 over to the 40mm headers? What jetting changes are required?
Doug
PostPosted: Sat May 06, 2006 7:55 pm
ALL 750 Pasos have SAME exhaust hole in sylinder heads, and connecting flage measurements are same, so no any problem to fit 40mm header pipes to 750 Paso. Worst thing is to find such 40mm headers! Surely need rejetting, if put open pipes to Ducati. But this is not very simple thing, so it needs long story to tell, but if i say it "simple": all open exhaust/inlet system modifications need rejetting. But with Weber its not so simpple thing... no!
Ps, i dont know exact USA Weber jettings, but i can find from my notes, what jettings are very close to EUrope Paso with Weber and 40mm headers.... :thumbup:
Users browsing this forum: Google [Bot] and 19 guests
