ducatipaso.org • View topic - carburetors out of whack, 750 paso
It is currently Fri Mar 06, 2026 11:23 pm
 Post subject: carburetors out of whack, 750 paso
PostPosted: Wed May 31, 2006 4:33 pm
PostPosted: Wed May 31, 2006 8:31 pm
 Post subject: Re: carburetors out of whack, 750 paso
PostPosted: Wed May 31, 2006 8:47 pm
PostPosted: Wed May 31, 2006 9:45 pm
PostPosted: Thu Jun 01, 2006 1:01 pm
PostPosted: Thu Jun 01, 2006 1:04 pm
PostPosted: Thu Jun 01, 2006 1:33 pm
No kidding ... FCR's ain't cheap.
If you want to work on tuning the Weber some, send a PM to jfiore - he has a great write-up detailing his experiences with the Weber. He's worked his into shape, and has the recipe for anyone else to follow.
There's a handful of links in the about it, too
1988 Paso 750 #753965
1997 Monster 750
PostPosted: Thu Jun 01, 2006 6:23 pm
here`s some more info about Webers from David Harvey`s old site
http://www.geocities.com/750paso/paso/906carb.htm
http://www.geocities.com/750paso/paso/906carb2.htm
and from Baukes
http://www.geocities.com/750paso/paso/weber.html
http://www.geocities.com/750paso/paso/f ... blues.html
don`t change to FCRs if you aren`t after a performance boost. But also if you are this modification should come with others. Therefore the stock Mikuni from a Supersport/Monster is the better and cheaper choice if you just want a reliable carb.
However, the Weber can work nicely it just needs some more attention.
Hope the links help.
PostPosted: Fri Jun 02, 2006 10:17 am
PostPosted: Mon Jun 05, 2006 1:45 am
Redpaso
