ducatipaso.org • View topic - Question for the Experts on electrical / fuel pump issue
It is currently Tue Mar 03, 2026 3:27 am
 Post subject: Question for the Experts on electrical / fuel pump issue
PostPosted: Sun Jun 11, 2006 9:32 pm
PostPosted: Sun Jun 11, 2006 11:00 pm
PostPosted: Mon Jun 12, 2006 1:01 pm
PostPosted: Mon Jun 12, 2006 1:52 pm
PostPosted: Mon Jun 12, 2006 4:08 pm
PostPosted: Mon Jun 12, 2006 7:10 pm
 Post subject: Re: Question for the Experts on electrical / fuel pump issue
PostPosted: Sun Jul 02, 2006 11:28 pm
PostPosted: Thu Jul 06, 2006 10:53 pm
PostPosted: Fri Jul 14, 2006 9:52 am
 Post subject: A Fuel Pressure solution for the webber?
PostPosted: Sat Jul 15, 2006 8:53 pm
Some where someone said something about the pump only putting out a max of 3psi. Someone else has said that part of the problem is that it is a pulse pump. How can a pump that is only putting out a little to much pressure but has an unresticted return line back to the tank be the problem? If I was to move the fuel filter from before the pump to after it. Either before the Y or between the Y and the carb this would give an air filled surge chaimber to reduce the Pulse and if it were on the carb side of the Y then it would reduce the flow and pressure to the carb. All very unscinetific but simple. I have the system apart at the moment and I think there is enough room to put the filter just before the carb if i use a couple of 90o bends.
Thoughts anyone
PostPosted: Sun Jul 23, 2006 5:13 pm
