It is currently Wed Oct 01, 2025 4:26 am
[ 4 posts ] |
Author |
JWilliam
Post subject: Quick fix for insecure instrument panel Posted: Wed Jul 05, 2006 5:14 pm |
Joined: Wed Oct 06, 2004 12:00 am Posts: 327 Location: Nottingham, UK
Top |
Vickon
Post subject: Insecure Instrument Panel... Posted: Thu Jul 06, 2006 5:32 pm |
Joined: Mon Feb 21, 2005 12:00 am Posts: 93 Location: Florida
Top |
desmodave
Post subject: Re: Quick fix for insecure instrument panel Posted: Thu Jul 06, 2006 9:08 pm |
Joined: Sun May 07, 2006 12:00 am Posts: 150 Location: castleford.west yorkshire.england
Top |
JWilliam
Post subject: Quick fix for insecure instrument panel Posted: Sat Jul 08, 2006 11:01 am |
You will need; sticky backed Velcro strips (only about 3 inches) and half ball rubber pads (used for floor standing speakers, desk top computers bases etc and are about 8mm x 16mm – H x W) and metal plate edging. This fix is only applicable if your Paso has the complete full fairing. Remove the front fairing upper cowl, the headlight, foam rubber upper surround for the instrument panel and instrument box. Remove the rubber dowels from the instrument box but don’t take out the studs that the rubber cylinders attach to, they can be retained. Clean the locating bosses that normally take the instrument mounting dowels and stick on the half ball pads, the instrument panel will rest on these. Now to the Velcro, take the clear cover of the instrument box and stick one side of the Velcro strip to the side and top of the clear cover. Next attach the Velcro to the foam rubber upper surround for the instrument panel making sure that you carefully match locations, so that when reassembled the clear cover will hook to the rubber foam surround. Make sure the metal plate that joins the left and right side of the fairing has an edging because the lower side of the clear cover will contact this. Reassemble the parts. The instrument box will rest on the half ball pads and the clear cover will be fastened to the foam rubber upper surround: with the assembly being pulled onto the half ball pads by the cables to the instrument panels. Clever.
Top |
[ 4 posts ] |
Users browsing this forum: No registered users and 1 guest |
