ducatipaso.org • View topic - What spark plugs are best?
It is currently Tue Mar 03, 2026 2:45 pm
 Post subject: What spark plugs are best?
PostPosted: Mon Jul 10, 2006 11:44 pm
What spark plugs are people useing? I took mine out and found that there were NGK's in it but they were no even the same as each other. The manual has Champion RA6YC in it.
PostPosted: Tue Jul 11, 2006 12:03 am
NGK's are good spark plugs.
PostPosted: Tue Jul 11, 2006 2:21 am
Hi Jon
While the bike is apart I was looking at doing the wiring upgrade. When I look at the photos of your bike it almost looks like a different bike. My bike is very original and although first registerd in 1990 I would say it was made late in 88. My Rgulator is on the right hand side of the bike. I have a large ignition box where your regulator is different rear suspention, carbs, cans and different coils. not a problem just interesting how different two bikes can be.
Have you put a relay on the headlight?
PostPosted: Tue Jul 11, 2006 6:18 am
All the spark plugs are quite similar.
The most important thing is the clearance, rather than the brand.
PostPosted: Tue Jul 11, 2006 9:12 am
Well, when my Paso was still completely original it came with Nippon Denso plugs. The bike of course was back-firing occasionally and when I changed them to NGK and then to NGK Iridium plugs things became even worse.
Since then I`m using Champion RA6HC plugs and am very happy with them.
I don`t say the other plugs are bad as with a good setup of ignition and engine they may have worked fine, but Champions were never so picky.
The RA6HC replaced the RA6YC longer time ago.
Gerhard
PostPosted: Tue Jul 11, 2006 11:20 am
Thanks. I just bought the Champions RA6HC's They are 1/4 of the price of the NGK Iridium plugs and they had them in stock. Sometimes 4 times the price is not mean it's better for every aplication.
PostPosted: Tue Jul 11, 2006 12:51 pm
PostPosted: Thu Jul 13, 2006 8:45 pm
 Post subject: Champion plugs
PostPosted: Mon Aug 07, 2006 2:38 am
I switched to the Champion plugs and the bike ran much better than with NGK plugs. And yes, they are cheap, when you find them. I went to 4 different Autopart stores to find them. When the guy told me that they were only $1.50ea, I just took 4 and put the spare pair in the tool kit.
Phil
