ducatipaso.org • View topic - engine transplant options
It is currently Sat Mar 07, 2026 3:23 pm
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
PostPosted: Mon Jul 17, 2006 8:09 am
PostPosted: Mon Jul 17, 2006 8:25 pm
the first 750 Elefant engine was the same as the one of the Paso including Kokusan ignition, but with the difference of using lower compression pistons. (9.3:1)
From 94 on the engine was the one of the Supersport, wet clutch.
PostPosted: Tue Jul 18, 2006 8:56 pm
A couple of engine have gone recently on Ebay for under £500 they do turn up and any breakers that have them want shot pretty quickly - MCN is showing a few breakers that have broken Paso's so probably worth a shout. Most breakers buy the bikes just for the bodywork and mirrors !
And I can vouch for that fact that airbox phase 2 was looking like quite some piece of work in May :thumbup:
Who has quoted for the Gas flowing and the cams ? local ?Sheppo ?
If cylinders need replating I can maybe assist with that and also if new pistons are required through a few contacts - cams might be harder but at that price why not just send yours to Kent to be reprofiled - a friend had four cams done for a TL1000 for around £300 which is cheaper than any of the after market camshafts I've seen for a 2 valve Duc.
I would think both Tony Brancato and Baines racing are worth a call.
Also if you can put up with the fact he's a total miserable gut half the time trty AJ Racing in Gloucestershire
PostPosted: Wed Jul 19, 2006 11:15 am
PostPosted: Sun Jul 23, 2006 9:03 am
How is the engine from a 750SS different to the paso engine?
I was thinking the mounting points might be way out, but the basic config of the engine seems the same. if anyone knows of any huge problems with compatibility let me know. thanks
PostPosted: Sun Jul 23, 2006 7:59 pm
Just for who thinks about M900 transplant, in this picture you can find the parts that need to be "cutted" to fit paso frame...
(hard work, isnt'it?)
:screwy:
PostPosted: Sun Jul 23, 2006 10:48 pm
si troppo!...
well it was a thought anyway... they look so similar
PostPosted: Sun Jul 23, 2006 11:39 pm
what about the option of swaping in a 97 748 motor?
PostPosted: Mon Jul 24, 2006 7:32 am
PostPosted: Mon Jul 24, 2006 4:19 pm
Go on this sounds like a fun "virtual project" what is needed internally ?
Post up a list - I bet we can between us source them for half the price - then just rock up with a big box of bits and say "ere mate build this"
:D
Users browsing this forum: No registered users and 33 guests
