ducatipaso.org • View topic - Started Looking at My Paso Project Bike
It is currently Sat Jun 20, 2026 8:08 pm
Post new topic Reply to topic  [ 139 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 10  Next
PostPosted: Wed Aug 02, 2006 2:09 pm
PostPosted: Wed Aug 02, 2006 2:50 pm
-Craig
PostPosted: Wed Aug 02, 2006 5:31 pm
I think I know why the instrument cluster was zip-tied to the bike......those vibration dampeners retail for $16 EACH!!! :thumbdown: I was figuring $5-$7 each. The huge one for my Harley can be had for about $2.50. My local dealer just had three in stock and gave me a "deal" on them for $12 each since they will probably never have to restock them.
Disappointing news is that the one exhaust ring that I need is not available anymore. This is the part that holds the pipe to the head. I'm gonna look around, but may get a buddy of mine to cut me one out of 1/4" plate steel with his plasma cutter. The inside groove may be easy to cut by making a holder and turning it on a lathe. I'll email a couple of places first, to see if they have one, because I can't picture anyone having a spare just floating around. :sad:
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Wed Aug 02, 2006 7:07 pm
And here i was thinking of asking $2 apiece for mine! WRONG! :thumbdown:
PostPosted: Wed Aug 02, 2006 7:17 pm
-Craig
PostPosted: Wed Aug 02, 2006 7:44 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
 Post subject: Hi!
PostPosted: Fri Aug 04, 2006 7:56 am
 Post subject: Re: Hi!
PostPosted: Fri Aug 04, 2006 1:30 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Mon Aug 07, 2006 1:44 pm
Vicki and I worked on the bike some more this weekend. Here's page two....
http://www.desmodemon.com/paso_project_1.html
Looks like we got most of the electrical issues taken care of, at least, according to the multimeter. I did run across one thing that I would like someone's opinion on.
The two pairs of wires coming from the ignition pickups are wrapped in a cloth-type material. This material is in very poor condition and falling apart. I removed a bunch of it and am debating if I should replace it with some type of insulating conduit. The reasoning behind this is that I know that, sometimes, when you have a wire with current going through it sitting parallel to an inert wire, a current can be induced into the inert one by the one with the initial current. Could this be an issue?
Now, I'm waiting for some parts to come in this week, and I'll have the exhaust reinstalled, then, it'll be time to pull the carbs and intake runners off the heads.
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Mon Aug 21, 2006 1:29 pm
Well....got around to messing with the bike some more this weekend. I took the vertical carb off and happened to look inside the head and saw this....
Comments?
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Mon Aug 21, 2006 1:53 pm
Looks like the project just took on a new dimension. Is the valve frozen in the guide? This may explain why the intake system was slap dashed back together? Hope this is all you find on tear down.
PostPosted: Mon Aug 21, 2006 2:05 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Mon Aug 21, 2006 2:38 pm
Could be the grinding is just factory casting cleanup, on the other hand, if home grown attempt at porting, could be good, could be bad. Place to check is valve seat to head[in port] interface. If sharp edges, more than likely factory cleanup. Attempt at smoothing and blending would be more than likely done later. Although, don't remember back in the day if Ducati blended seat port area.[only tore down a few]
PostPosted: Mon Aug 21, 2006 8:53 pm
yours look pretty much normal I`d say. These here were rebuilt and modified.
[/url]
PostPosted: Tue Aug 22, 2006 12:59 pm
Cool.....Everything looks normal, compared to the other head. I'm just glad that this thing wasn't any more "Mickey Moused" than what I've seen, already. Here's the horizontal head's intake port...
I've cleaned the carbs and checked the jetting, and all looks well, there, too. I just need to buy a couple of rebuild/gasket kits. Looks like I'll be surfing a little bit today for the best prices and availablity.
Edit - The carbs are Dellorto PHF 36's and one is marked "MD" and one is marked "MS". The only difference that I can see is where the idle adjustment screw is located. Is there a reason for these to be different?
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
Users browsing this forum: No registered users and 29 guests
