ducatipaso.org • View topic - Speedometer
It is currently Tue Jun 16, 2026 6:37 pm
 Post subject: Speedometer
PostPosted: Sat Aug 05, 2006 1:43 am
70 hp. can change the world
PostPosted: Sat Aug 05, 2006 1:54 am
PostPosted: Sun Aug 06, 2006 12:26 am
I would contact some race shops, most racers take the speedo drive off and substitute an aluminum spacer, somebody must have a stack of them somewhere!
PostPosted: Sun Aug 06, 2006 7:08 am
You mean this?
http://it.msnusers.com/pasochisti/shoeb ... &PhotoID=9
There's a ratio number punched in the body, mine is 21/12 and refers to the gear inside it.
I happened the same thing and I went searching to an "used spare parts fair" (is there a sigle word for this?)
You must take care not to find a left spinning speedo, even if a similar ratio (such as 19/11) will do
PostPosted: Mon Aug 07, 2006 1:48 pm
the speedo angledrive of the Aprilia RS125 was mentioned once on the mailing list.
I wonder if that is correct though as I think the 125 has 17" wheels, doesn`t it ?
PostPosted: Mon Aug 07, 2006 11:16 pm
Thank you. I'll go to an Aprilia dealer with my broken speedometer. I'll remeber the ratio, Ducapaso. :thumbup:
Paso 750, Aprilia RS 125 has a 110/17 tire, maybe it is aproximately like 130/60-16 perimeter. I use in my Paso 130/70-16.
Users browsing this forum: No registered users and 53 guests
